-   -   Rear sway bar mounting point question on a '74 (http://forums.pelicanparts.com/porsche-911-technical-forum/650890-rear-sway-bar-mounting-point-question-74-a.html)
tdskip 01-14-2012 06:43 PM
Hi guys - my car didn't have a rear bar on her (which is correct for the year) when I got her and I'd like to add one.
Is this my factory mounting point? Yeah, know it is bent.
Think I can bent it back without it weakening the metal too much?
http://i207.photobucket.com/albums/b...tos/mount3.jpg
Thanks guys.
DRACO A5OG 01-14-2012 06:48 PM
Yes it sure is, check the weld points for fracture after you bend back. You should be fine.
If the mount nuts are stripped ( they are very soft), use SS Grade 8 Bolts and Lock nuts from ACE. They woked great for me.
tdskip 01-14-2012 06:52 PM
You know Jim, I was worried there for a couple of minutes because it took you all of like 5 minutes to answer my random question on Saturday night. Try to be more prompt next time, ok?
Holy cow you guys are great.
I'll look for cracks. Thanks!
Tidybuoy 01-14-2012 07:52 PM
This is what's on my '74. I believe it is the Weltmeister bracket but I'm not sure as it was there when I got the car. This clamps onto the torsion tube.
http://forums.pelicanparts.com/uploa...1326599513.jpg
http://forums.pelicanparts.com/uploa...1326599539.jpg
JeremyD 01-14-2012 08:00 PM
If you run sticky tires I'd shoot for either the buckley racing Buckley Racing - 911 Car Prep
or wevo mounts
tdskip 01-14-2012 08:11 PM
These?
http://www.buckley-racing.com/images...swaymounts.jpg
JeremyD 01-15-2012 11:20 AM
yep = those are the ones... The weld to the tub and the torsion bar
DaveA 01-15-2012 02:24 PM
Best thing to do is to weld a reforcing plate on the inside of the mounts, and keeping the orginal mounts.
R/Dave
Walt Fricke 01-15-2012 02:49 PM
I'm with Dave A. If you had no mounts at all, either a torsion tube mount or a much reinforced weld-on mount like the WEVO would commend itself.
But you already have mounts. If you reinforce them (which is not hard if you can weld at all, and not expensive if you can't), they will stand up pretty darn well even when abused.
Reinforcing typically amounts to cutting a piece of siutable sheet metal to roughly the size of the vertical part of the mount, and welding it on, creating a kind of enclosed space where the nuts are. Someone also sold a sort of X shaped reinforcement, allowing access to the nut in case it strips or its weld breaks and you need to hold it with a wrench for R&Ring the sway bar.
tdskip 01-15-2012 04:21 PM
Thanks guys - I do weld so I'll look at making some reinforcing plates.
Can I switch gears a bit and ask about the rear bar I bought? This was listed and confirmed over the phone as being a "drop in" for my '74. I don't have access t the car and the bar in the same place, so forgive me for not actually trying it.
This looks right as it will push on to the mounting point on my trailing arm.
http://i207.photobucket.com/albums/b...os/rearbar.jpg
Here is the bar side detail.
http://i207.photobucket.com/albums/b...s/rearbar3.jpg
And detail on the side.
http://i207.photobucket.com/albums/b...s/rearbar2.jpg
1976 TN Porsche 01-15-2012 04:52 PM
Looks like you have got the right drop links but you have the wrong swaybar. Your swaybar looks like one from a later model 911. I think you will need one for the early model cars. Here is what I have on my 1976 911S. The swaybar in the background is the early style and the one in the foreground is the later style. Hope this helps.http://forums.pelicanparts.com/uploa...1326675088.jpg
tdskip 01-15-2012 05:00 PM
Sigh, hence the question. Thanks for confirming my suspicion.
So basically I got totally shafted by the Pelican guy I bought these from then. I had that guy feeling but decided to trust the guy. He also sent a front bar that was the same size that I already have (stock). Grrr.
1976 TN Porsche 01-15-2012 05:09 PM
That is pretty rare. I have never had a Pelican do me wrong. Don't let this one experience change your mind about the Pelican community. There are real good people here.
tdskip 01-15-2012 05:47 PM
Yes, agree, lots of good people. The help I've received as a newbie has been just amazing. Everyone has been very generous with their time and experience.
I took part in the SoCal part out part last weekend, which was a hoot. Good folks.
I've bought wheels, door pockets, and a bunch of other bits. All came as promised or better.
But this seller was a snake. He sent me the stock front bar (which I had of course) and then this one for my 1974. I'm pissed.
PropellerHead 01-15-2012 06:01 PM
What is the diameter of the rear bar? I have a 'proper' rear bar (for the '74 drop links you have) and may be willing to trade you straight across for the one you have. Provided the diameter is okay.
I'm looking to go the other way as my car doesn't have the receiver ball on the trailing arms and yet I have a bar to utilize them.
PM me.
Cheers,
Chet
tdskip 01-15-2012 06:05 PM
It is an 18mm bar.
PM sent Chet.
1976 TN Porsche 01-15-2012 09:42 PM
Cool.
tdskip 01-16-2012 05:57 AM
Yeah. Like you said 1976, good people here for the most part.
aston@ultrasw.c 01-16-2012 07:38 AM
X2 the best!
chrismorse 01-16-2012 07:39 AM
If you have an 18 mm rear bar, the front bar should be 20 mm. This bar set is the "Carrera" option. If the front bar is thinner, you willlikely have a lot more oversteer.
Some of the rear mount solutions, like Wevo, are made for later year models, that is the bolt spacing is 10-20 mm wider, so you will need bigger straps. The good news is that you can then buy poly bar mount bushings, which are not available for the 74 narrow mounts.
Here is a link to my fix with the Wevo mounts:
http://forums.pelicanparts.com/porsche-911-technical-forum/617072-replacing-rear-bar-mounts-74-911-a.html
Is your fuel pump still in the back stock location??
hth,
chris
tdskip 01-16-2012 07:59 AM
Great thread Chris, very well documented.
I have a 3.2 in my '74, will need to double check fuel pump location.
Is the factory early style bar likely to present fuel pump fit issues, or is that more likely with the later ones?
I'm not going to be racing her, and can/will reinforce the factory mounts to box them in. That should hold up OK, no?
Thanks guys.
tdskip 01-16-2012 08:02 AM
I have a 20mm bar on the front, was going to stay with a 18mm or 15mm from factory to keep things under (to the best of my sketchy abilities) under control.
chrismorse 01-16-2012 08:20 AM
Thanks guys.
The factory bar will fit just fine, but the fuel pump mounting bracket is kind of in the way for welding in reinforcements. You may be able to sneak in there and get enough reinforcement welded up. On the advice of Grady Clay, i moved the mump up front.
The right mount was all twisted and ripped up, the left was cut, propably with a sawzall, as you can see inthe photo.
My dad bought the car new, and ordered the carrera bars. Even though he was a very conservative driver, the bigger bars still ripped off the stock mounts, so i think anyone with an 18 rear bar would be advixed to weld in more support before the sheet metal fatigues.
http://forums.pelicanparts.com/uploa...1326730831.jpg
chrismorse 01-16-2012 08:29 AM
If my math is right, the 18 mm bar is just a touch more than twice as stiff as a 15mm bar, (bar diameter to the 4th power for comparative purposes).
, so, it might be better to stay with the factory balance.
However, i drove the car for several thousand miles with no rear bar and the 20mm front bar and street driving was just fine.
With both bars, the car was much flatter and had better balance.
dazed and confused,
chris
bkreigsr 01-16-2012 08:56 AM
These drop links will work fine. They have already been modified to work with the later style 'bolt thru' bars. (See that bronze bushing in there?)
You now have to get a matching bolt long enough to go through everything and not have any slop in the drop link bushing (diameter-wise), once hooked up.
Bill K
tdskip 01-16-2012 09:27 AM
oh, and you have not been 'shafted' by a fellow Pelican.
Bill K
Thanks for the note Bill. Very willing to admit if I'm wrong here, and I am a newbie, but I got a 20mm stock bar and not 22mm front bar I ordered and paid for.
Again, hope I'm wrong here but I don't think the later year bar I received will work with the stock mounts on a 1974, will it? Won't the rear bar that I was sent require new mounts be fabricated?
bkreigsr 01-16-2012 10:04 AM
Depending on what hardware you received with the purchase, you should be good to go. In fact, those modified drop links will accept a range of diameters, whereas the stock - unmodified - links will only accept different diameters if you swap out the rubber bushings.
If you still have the mounts on the car you showed in your first post - you should not require any fabrication.
Again, if you are running anything heavier than the stock 18mm bar - keep an eye on the factory mounts and welds - especially if you have to really tweak it to get it back to spec.
btw how are you measuring the diameter?
fwiw, I'm using a 22mm bar from an 87 on my 77 with a modified drop link - no problems.
Bill K
tdskip 01-16-2012 10:46 AM
Hi Bill - thanks for the help.
I'm using a digital caliper measuring the bar at mid-point. Is that correct?
Here are some pictures of how the bar would need to fit based on what I have;
I didn't receive any mounting brackets, and please excuse the obviously incorrect bolt, it was just there to help mock it up.
The bar will be required to be mounted at a downward angle if that matters. Totally open for other ideas / corrections if I've got this wrong.
http://i207.photobucket.com/albums/b...os/mock-up.jpg
http://i207.photobucket.com/albums/b...s/mock-up1.jpg
http://i207.photobucket.com/albums/b...s/mock-up2.jpg
bkreigsr 01-16-2012 11:52 AM
That's the ticket.
do yourself a favor and replace those black bushings on the chassis mount. downard angle is normal.
Here's the bolt that I used: McMaster-Carr 95430A423 M12 x 80mm, 1.75 mm pitch, 10.9 Stl, hi viz Blue Hex Cap Screw. (of course any M12 x 80mm should work)
Bill K
tdskip 01-16-2012 12:02 PM
Bill - thanks for the coaching here. Glad it looks like I can make this work, even it ir require replacing the bushings and tracking down brackets that were supposed to be included.
Chet - another PM sent.
I sent the seller a note indicated that I got the details wrong on the rear bar and apologized for that.
tdskip 01-22-2012 09:03 AM
Hi guys - anyone know off hand what the bolt pattern is for the actual sway bar bracket mounts? I thought I found M8x18 but that is a bit of an oddball thread...
Walt Fricke 01-22-2012 02:38 PM
TD
The stock bolts to hold the U shaped sway bar bushing holder to the "welded to the chassis" bracket is M8x1.25 thread. That is the standard and common thread for 8mm bolts/nuts.
There is no such thing as an "18" metric thread, at least outside maybe Swiss watches. 18 threads per mm would be mighty fine indeed.
It is just possible that a thread length of 18mm would be adequate for this job. You need enough for a washer, two bracket sheet metal thicknesses, and the nut welded on the top of the chassis bracket.
Good news is that you can use longer bolts as long as they are full thread. There is room above the bracket for a fair amount of extra. If you don't have a bucket of old 8mm bolts saved from previous projects, just go to a decent hardware store and get some. Not a critical part like, say, a rod bolt or flywheel to crank bolt.
tdskip 01-22-2012 08:50 PM
Thanks Walt
bkreigsr 01-23-2012 04:23 AM
should be a regular M8 x xx(length) x 1.25 thread. the captured nut might be a nylock, or similiar type, so you can't finger tighten the bolt all the way home. Bill K
Walt Fricke 01-23-2012 06:58 PM
In fact, you want slightly longer bolts for this application, especially since you don't have adjustable drop links. There is apt to be some preload involved, so having longer bolts will allow you to draw the bar up into place without a huge struggle.
tdskip 01-24-2012 05:52 AM
Thanks Walt.
I do have a question on installing the drop link - do I tap the "cup" part of the drop link on to the ball shaped mounting point on the trailing arm? Assuming I should put grease in the "cup" part of the drop link before installing it (and cleaning the trailing arm mounting point).
bkreigsr 01-24-2012 06:19 AM
I use a broom stick cut to about 15" long (so it extends past the bodywork) under the springplate and give a firm rap with a BFH. I suggest you do that part first, then do the bolt-on part - adjusting the body height with a floor jack, if you have to, to get the holes to align. Bill K
tdskip 01-24-2012 06:37 AM
Got it. How much and what type of grease to use in the cup?
