G50 Gearbox synchros
At normal revs it's a very crunchy exercise to change especially from 1st to 2nd gear.
Are there any remedial solutions or do we have to rebuild the box?
Being a 100k mile car, should we replace 'everything' that moves or just those parts, which are worn?
Anything else please, that I should consider doing once the gearbox comes out?
Thanks and cheers from N.Z.
Old 09-23-2014, 09:09 PM
With replacing some of the internal parts, is it important to stick to genuine Porsche or can we use aftermarket?
And if so, what brands would you suggest please?
Old 09-24-2014, 07:27 PM
Tony
Maxhouse97's Avatar
Beware on steel synchros from Porsche - I've heard they recently changed suppliers and have had quality issues with the new parts. Matt from GT could speak more intelligently about it, but my mech had to find some old ones that were still good.
Old 09-25-2014, 05:03 AM
I was convinced my syncro was shot on 1st but it works perfectly again after changing the clutch and greasing the input splines ,112000 mi
.The clutch was dragging . 100k is low for worn out syncros on a g50
How many miles on your clutch?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 09-25-2014, 07:40 PM
ganun's Avatar
Yep look at simple things first, bleed the clutch, have fresh oil in the trans, I like Redline NS in my 87 G-50 BIG difference in shift quality. Pedal travel also.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 09-25-2014, 07:49 PM
gearhead
I always recommend replacing parts as assemblies. If it is in your budget, get a new 1/2 slider hub assembly in addition to the 1st and 2nd gear synchros. If you aren't racing the car and downshifting into 2nd,you don't need the steel version there.
As mentions stick with OEM at a minimum. The dealer brass synchros are OK. I probably wouldn't trust their steel version. And above all else don't buy the cheap knock of R&S versions you can buy for 75 cents on the dollar of what the OEM ones cost.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-25-2014, 10:08 PM
Thanks for all the advice, much appreciated.
The car has done 110,000 miles, so just run in!!
Interesting to hear about the Clutch option and the Input Splines, etc. It sounds like we could certainly start with looking at these options first.
Will ask one of the 'specialists' to take it for a drive and see what they say.
Old 09-26-2014, 01:59 AM
E-85 sippin drunk
turbobrat930's Avatar
Another source is Jim Patrick at Patrick motorsports. I bought my race prepped G-50/50 box from him. Great guy to deal with
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-26-2014, 05:39 AM
There is a special grease speced by Porsche for the input splines ..I used the small packet supplied with the new Sachs clutch. Wire brushed the splines .The clutch drag is almost imperceptible except the stick would be hard to pull into neutral at times and the car would move slightly while starting it in gear with the clutch pedal pushed down. I changed the master and slave cylinders ,then the motor mounts all of which helped but it still crunched shifting into first until I changed the clutch. I,m very glad I didn,t rush into an expensive trans rebuild. If you have weak syncro issues in all gears I would suspect this for sure, I was fooled by it only seeming to be 1st gear which crunched ,but now all gears engage better and the crunching on first has stopped completely.
It,s a fairly common issue with a 100,000 mi clutch. I found the original 1994 dated assembly in my 95 when I changed it last winter at 110000 mi. and the splines were very dry and rusty. rennlist has a number of threads referencing dragging clutches on both 993 and 964,s
1995 993 coupe
2012 Boss 302
Old 09-26-2014, 07:23 AM
OsoMoore's Avatar
Seconded. My 915 synchroes from R&S had to be sent back and I lost a week of summer driving waiting for new OEM ones to arrive.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 09-26-2014, 08:53 AM
You guys are truly awesome. I have taken note of all your suggestions and advice. I'm not technical enough to tackle the gearbox or clutch myself, but with this new knowledge in hand I will now visit a couple of Porsche 'specialists' and see what they have to say, after driving the car.
Old 09-29-2014, 12:56 AM
Where in Nu Zulund are you located ?
Old 09-29-2014, 01:02 AM
gearhead
There's Motorscience and Powerhaus who are both perfectly capable of servicing a G50 for you.
Regards,
Matt
Old 09-29-2014, 09:12 AM
