G50 Gearbox synchros
At normal revs it's a very crunchy exercise to change especially from 1st to 2nd gear.
Are there any remedial solutions or do we have to rebuild the box? Being a 100k mile car, should we replace 'everything' that moves or just those parts, which are worn? Anything else please, that I should consider doing once the gearbox comes out? Thanks and cheers from N.Z. |
With replacing some of the internal parts, is it important to stick to genuine Porsche or can we use aftermarket?
And if so, what brands would you suggest please? |
Tony
Beware on steel synchros from Porsche - I've heard they recently changed suppliers and have had quality issues with the new parts. Matt from GT could speak more intelligently about it, but my mech had to find some old ones that were still good.
I was convinced my syncro was shot on 1st but it works perfectly again after changing the clutch and greasing the input splines ,112000 mi
.The clutch was dragging . 100k is low for worn out syncros on a g50 How many miles on your clutch?
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Yep look at simple things first, bleed the clutch, have fresh oil in the trans, I like Redline NS in my 87 G-50 BIG difference in shift quality. Pedal travel also.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
gearhead
I always recommend replacing parts as assemblies. If it is in your budget, get a new 1/2 slider hub assembly in addition to the 1st and 2nd gear synchros. If you aren't racing the car and downshifting into 2nd,you don't need the steel version there.
As mentions stick with OEM at a minimum. The dealer brass synchros are OK. I probably wouldn't trust their steel version. And above all else don't buy the cheap knock of R&S versions you can buy for 75 cents on the dollar of what the OEM ones cost.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks for all the advice, much appreciated.
The car has done 110,000 miles, so just run in!! Interesting to hear about the Clutch option and the Input Splines, etc. It sounds like we could certainly start with looking at these options first. Will ask one of the 'specialists' to take it for a drive and see what they say. |
E-85 sippin drunk
Another source is Jim Patrick at Patrick motorsports. I bought my race prepped G-50/50 box from him. Great guy to deal with
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
It,s a fairly common issue with a 100,000 mi clutch. I found the original 1994 dated assembly in my 95 when I changed it last winter at 110000 mi. and the splines were very dry and rusty. rennlist has a number of threads referencing dragging clutches on both 993 and 964,s
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 Last edited by johnsjmc; 09-26-2014 at 06:28 AM.. |
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
You guys are truly awesome. I have taken note of all your suggestions and advice. I'm not technical enough to tackle the gearbox or clutch myself, but with this new knowledge in hand I will now visit a couple of Porsche 'specialists' and see what they have to say, after driving the car.
Where in Nu Zulund are you located ?
gearhead
There's Motorscience and Powerhaus who are both perfectly capable of servicing a G50 for you.
Regards, Matt |
