Elombard's Avatar
? nuts washers that are used on dash pad
I cant remember which nuts and washers hold the dash pad on. Anybody have a photo of the back side of a dash pad that has the nuts and washers or has a picutre of just nuts and washers? Size and thread pitch is helpful too but I think if I have a picture I can find them in my pile :-)
Are they the same as the little ones that hold on the knee pads? I thought I remembered them being larger ~11 or 13 mm.
I searched the bbs and looked at the pelican catalog and I dont see any info in either place.
Need to do a better job labeling baggies!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 05-22-2016, 11:17 AM
Most are the small 5mm, 8 socket
Bruce
Old 05-22-2016, 11:37 AM
Discseven's Avatar
Close as I could get for you Erik...
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-22-2016, 02:34 PM
Elombard's Avatar
karl I actually need the Nut that screws on their. Thanks so much!
The nuts that hold the knee pads use an 8mm socket. I thought the nuts for the dash were larger.
Old 05-22-2016, 03:00 PM
Discseven's Avatar
Welcome Erik. I believe Bruce is correct with the 5 / 8 mm socket but am not sure so cannot confirm with certainty. I used nylocks. Not as easy to get off as regular nut but then they'll stay in place with just snugging them.
Karl ~~~
Old 05-22-2016, 05:13 PM
