bronken torsion bars
I have a 1988 Porsche 930
It puts out about 410HP with about 450lb torque.
It has broken 2 torsion bars. The were upgraded to the hollow 30mm bars.
The car has broken 2 of them on the right side.
As far as we can tell the only thing that could be breaking the bars is Torque....
Would the solid bar be better...
Would the softer 28mm or 26mm better for spring action...
Should I remove the bilstein shock and add a coil over in its place to help with the
torque effect?
Looking for some ideas and answers before I replace another bar....
Chris
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 01-22-2012, 10:00 AM
Diss Member
Quicksilver's Avatar
The engine torque can't effect the torsion bar unless it caused the suspension to go to full deflection. Suspension travel is the only force on bars.
Cracks can be caused by stress risers (scratches), corrosion, poor quality, or just plain dumb luck (least likely). Are the bars completely unmarred on the surface? Are they greased or protected from corrosion in some other manner? What brand are the bars?
There is nothing wrong with hollow bars but I would only use Sander or Elephant bars. I would also stay away from the Sway-A-Way bars as there are more reports of those cracking.
As far as the size: The rear size should be relative to the front size and is simply based on how much firmness you are willing to take in trade for handling.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-22-2012, 10:40 AM
agrimmitt's Avatar
Location: Mesa Oaks, CA: Zone 8>PCASB/PCACC/POC/NASA member
Send a message via Skype™ to agrimmitt
Question A little input and a few question
I would agree with Quicksilver, hollow bars are strong and just fine (I have and looked for a long period of time for Gary Sanders bars>front and rear) and are the type suggested by almost everyone. I don't have your hp, but I believe you don't have my suspension set up. Couple of questions, who indexed them at installation (happened twice now) and did you afterward have the car corner balanced. Do the bars show any corrosions from dirt or maybe salt? Third is the car lowered and is the camber modified heavily negative? Last are you running stock rims 16" or wide 15" rims in the rear.
art
Old 01-22-2012, 10:59 AM
Dave Colangelo's Avatar
+1 for protecting the bars with grease or some thing. I just did my rear bushings and did a good deal of reading on this matter. From what I understand you can replace the whole torsion bar system with coil overs if you like. That may be something to consider if you are willing to spend the money. From what I have read the coil overs are a direct replacement for the torsion bars not some thing that assists them. Although there has been talk of them being used together to get very high spring rates.
When they were replaced did you re-index the suspension?
What bushings are you using (original rubber/netrix/poly graphite/oil)?
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 01-22-2012, 11:15 AM
safe's Avatar
Elephant Racing bars = Sander bars
But I think ER are plated.
Magnus
Old 01-22-2012, 01:00 PM
Indexed
Yes the car on the last install was indexed and corner balanced.
The rear tires are 315/30 18 on an 11" porsche rim. Came from a 996 I believe
The bushings I dont remember what the mechanic put in there...There was
talk of solid race bushings. But I will not know for sure until I get it all apart.
The Torsion bars are the hollow type..and they are white from what I remember.
I will look at the elephant bars...But I will look at the cracks and corrosion when I get it out.
Chris
Old 01-22-2012, 03:10 PM
Send a message via Skype™ to Porboynz
Are they breaking in the same place, inboard or outboard? Right on the spline or in the middle? eg Maybe the spring plate is the issue if they are breaking on the spline outboard end.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 01-22-2012, 10:43 PM
Chris
Chris,
If they are painted white; those are Sway-a-way bars and they did have some heat treatment issues as I've seen this before.
I'd recommend installing Sander bars or Chuck's ER ones as they are made in the same place. Good stuff and nary a problem as long as the bushings are in top condition to prevent any rubbing.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-23-2012, 12:47 AM
