Real world experience with a Cayenne Turbo Series 1?
I am considering purchasing a 2005 Cayenne Turbo to add a automatic car to my tiny stable of 5 speeds. I found one in the colors I like Dark Teal/Palm Green, right miles, right price. I am just wondering how reliable they are? I know about the coolant pipes being upgraded from plastic to aluminum. (the dealer is checking on the upgrade) The car in question is a 1 owner, always dealer serviced, no stories, no paintwork 05.
The coils have been replaced and the tires/brakes are new. Any other "Gotcha's" to watch for? |
If you want you can PM me the vin, and I can see if I can get you an autocheck report.
I have the same truck " it's really a great car
But the gas consumption is just beyond ridiculous It's gonna blow your mind if your not used to it. I spend $400 a month on gas like nothing. You should also check the high speed vibration in the Steering wheel" very common and you will never fix it I tried everything.Rennlist has a good cayenne forum With lots of DIY topics. Good luck , |
Choco PM sent THANKS!
Avid - thanks for the feedback. I am blessed to be working out of a home office the most road time the Cayenne will see is as a season driver/weekend long road trip vehicle, so MPG would not be a huge factor for me. But I appreciate your feedback. Aside from the Cardan flex joints in the driveshaft, coils, coolant pipes, any other "gotchas"?
The carfax came back clean... so far so good? Thanks again, Andrew |
Headlights will make you crazy. Connections are bad and retention design is horrible. There is a Cayenne forum that addresses this. Otherwise, very nice vehicle . . . .
Autocheck sent.
Personally, I'd rather get a pickup or a nice Lexus RX (not really a guy's car but they're nice). |
Thanks All. I just got this back from the dealer.
I asked: "I would like to verify the following have been replaced: Coils have been replaced hopefully with -08 Part number* 07 version, installed 8/4/10 @ 94,888 miles Plastic coolant pipes replaced with aluminum "upgrade" kit**Our records show original Cost to replace $2k * Cardan Shaft replaced to new version or the center support bearing replaced** Original?, no documentation Front Control Arm Bushings have been replaced or in good condition Original? no documentation Does it have NAV PCM 2.0?* Can be updated to 2.0 with map data from 10/2009 Cost $500.00" They are asking $25,000. 113k miles 1 owner always dealer serviced. I am thinking it is worth $20k tops. Thoughts? Andrew |
nice truck but for that money with those miles Run Forest Run
ferrari if you want I can get you a list of TSBs/Recalls. I've got mitchells & alldata.
I started out with a new 04 Cayenne, I'm on my 3d one now. logged about 200k, with great reliability mostly just maintenance. I currently have a GTS and its the best of all.
Yes please! The dealer is down to $22500.
But why buy a 120k SUV when you could get another 912 for that money.
LOL Just amazing how fast these big Porsche's fall in value. Sure it makes the Corp some money, but a whole different kind of ownership experience. |
Did they make a AWD Automatic 912? :-)
Let me list what I have had to replace in the last few years "
and I maintain my cars very well " All work I have done myself Both Batteries 1 in trunk 1 under drivers seat $400.00 Coolant pipe upgrade " Mine cracked in front of my house $1000.00 in parts " 2 solid days of labor. Miserable Job Suspension Compressor $800.00 Suspension Computer in Rear $550.00 Suspension AIR Manifold $400.00 3 Suspension air lines $300.00 Both front Wheel level sensors $400.00 3 Coils $ used $200.00 Turbo Oil Line $100.00 Used Windshield $450.00 Snow was on it " I hit defrost it cracked 4 tires $1000.00 4 Rotors $800.00 Pads and Sensors $300.00 Headlight assembly $300 ebay Durametric Scanner $400.00 A must have item Rear hatch compression struts $260.00 This was a suck job Things that drive me nuts " High Speed vibration in steering wheel " Back window constantly must be adjusted to stop computer from yelling at you Gas consumption Stupid computer system constantly bosses you around like your an employee ( we frequently argue) factory alarm sometimes goes off for no reason at all Putting down rear seats " a little fussy some curse words seem to fix it Not trying to scare yu " Just showing you what Cayenne ownership is like Try and take the beast away from my wife " Never happen, Booty put on hold she loves that truck. I will say this... That truck is just stupid fast |
We have an 05 Turbo. Love it. We have cat bypass pipes on it and an IPD plenum. Very pleased. I have even tracked it for giggles. Nearly had a brake fire on the track.... :)
My only issue to date is the headlights. Currently one is testing my patience.... Tons of power, outruns just about everything out there, nice and comfortable, glad we have it. We are currently averaging 14.5mpg :( Cheers |
Great info. Can I ask how long you have owned your Cayenne? Is yours a 05 Turbo? How many miles are on your Cayenne?
Thanks! Quote:
Exactly 103k
Oh sorry for not seeing your post!
Here's all the TSBs, if you want specific info about 1 PM me. https://docs.google.com/open?id=0B--VMx_b_9MYNGM2ODIwNTUtZjA5OS00Zjc3LTkwNjQtNmYyZjcwY jA2Yjc1 There's only one recall in Ondemand and here it is https://docs.google.com/open?id=0B--VMx_b_9MYYzJhMjIwYmUtZGY1ZS00OTE0LTliOWUtYmFjNTJhM DJlYTEw For the shaking in the wheel- go get your wheels balanced by someone with a hunter roadforce system. |
| All times are GMT -8. The time now is 07:30 PM. |
