1989 motor mounts
Greetings,
During today's (unsucessful) attempt at replacing the Fuel Pressure Regulator (noted in the BG44K thread). I happened to notice something unusual when viewing the motor mounts on my 89. Although I don't have pics at the moment (but will tomorrow), my left side MM doesn't appear to be showing any degree of "rubber" as shown on the left side. I could run my fingers into the opening on the cross-member and easily detect a different spacing on one side vs. the other. The right side shows a healthy "rim" of rubber underneath it's bevelled washer....clearly the two side are not in symmetry. All parts look to be in place ......I'll look closer at the underside tomorrow....Here's what weird: I've a slight incline to my driveway, as I back out each and every morning.....I learned real quick that the skid "hooks" can/would scrape if the exit angle from the driveway wasn't correct...nothing new there......I would always accomodate this need. About 1 1/2 years ago, my wrench dropped the engine to take care of several things.....it was a few months later that I noticed that I could sometimes SCRAPE the exhaust tail pipe when exiting the inclined driveway (ODD)...only happened occasionally but certainly more frequent than BEFORE. Eventually, I noticed ACTUAL wear on the tailpipe (from it's scraping when exiting the driveway)....I never really gave it any further thought , other than to have the Wrench check things out, to make sure all was tight. One of the many parts handed to him on this engine drop was fresh motor mounts, MM bolts, curved and flat washers to reinstall. It now looks asymetrical at the mounts, based on the amount of rubber showing, as well as finger clearances, side-to-side. The left side seems to be "lower" than the right...I've not yet measured anything but the exhaust "looks" a bit lower on the left side than the right. Not to mention that I just recently experienced a LEFT REAR BROKEN SWAYBAR MOUNT......what gives here? (broken sway bar thread exists, already) Any suggested specifics to check? Should that rear cross-member be level (on level ground)? It almost looks like the curved washer on one side (has less pronounced "curvature" to it than the other.......I hope proper torque settings were applied......I provided all of the parts from Pelican. Any observations on this. Something's amiss..... ![]() BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Member 911 Anonymous
Hey Doyle,
I recent changed my Motor Mounts to the Cabriolet Mounts. The Coupe/Targa mounts are very soft and will deform over time. ![]() Left Mount removed, right Cab Mount installed.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
good idea to replace the rears (if old) and somehow check that the cross member and all the washers/etc. are in correctly, the trans mounts are a different story
Doyle
Sounds like the MMs were not installed correctly; at least one of them wasn't. Do you think he would own up to something like that and correct it?
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Indeed, thatis what I thought, but I could literally push the rubber in with my finger nails. Opposed to the cab mounts on the right, very rigid.
I'll get pics and more data today..press forward.......
Thanks for the replies! Doyle
you say you gave the wrench curved and flat washers. I believe all 4 washers are identical and should be slightly concave. They hug the curved rubber from above and below. I have also heard of the crossbar (to which the mounts bolt) being twisted or bent, because the mount nut was rusted in place and the bar bent before the mount's bolt broke loose.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
I AM curious as to the state of the crossmount.....we shall see. I'll get some pics later today! THANKS! Doyle
Doyle
Doyle, there is supposed to be a total of 4, 2 flat and 2 concaved washer.
Gotcha' DRACO,..of course, that would be per side
BEST! Doyle
per side there are 2 large curved washers and one small lock/split washer (which you're calling the flat washer - it really isn't because a flat washer is not split). the 2 curved washers are identical (same part number in catalog).
I'm sorry,...for one: I didn't realize that it's split. It's flatness is characterized in relation to the large curved (or better: concave) piece....for two: I didn't realize that only one of the smaller washers was used per side,....I assumed (I guess) there would be another on the bottom that would mirror the top config,..I guess I need to review my PET again...
Pics coming very soon, Gents. BEST! Doyle
Well,..let's see some more (resized) pics....
![]() ![]() ![]() ![]() ![]() ![]() BEST! ![]() Doyle
it looks like yours does use flat washers. mine has split/lock washers which are much smaller than those (barely larger than the bolt; you can't see them under the bolthead).
Now,..back to the issue......off to the races... Best, Doyle
Off to look at this issue,..with fresh PORSCHE MMs in hand,..decided to handle it myself....will update with pics and testimony.
Here goes............ Best! Doyle
