Young enthusiast
911 3.2 brake lights out
center light (on bottom of rear windshield) and right light not lighting up. This project not in 101 Projects.. how difficult a troubleshooting/install project is this?
TIA
BULLET 1989 Porsche Carrera 3.2 coupe |
On Tour
How hard depends on what is wrong..
Easy stuff I had issues with mine too an 88 coupe. First check to make sure bulbs are good. In my case it was the bulb sockets were worn and did not hold the bulbs tight as to give good contact. Solution was to add solder to the bulp "tip" contact area on the end. It made them very tight and burn bright. Another option is some of the new LED bulbs that are available seem to come with a longer contact area and consequently fit very tight on my car. If this is not the fix well... Harder stuff Going to have to start looking for loose/bad wiring. Poor ground etc... The more quailfied will need to weigh in to help you with this. Mike
- 2018 Cayenne S 958.2 - 1988 Carrera 3.2 Coupe Marine Blue (SOLD) |
What center light is at the bottom of the windshield?
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Brake Light.
In the interest of rear window visibility, the post '86 3.2 cars relocated the third brake light to the bottom of the rear window.
Are you referring to the passenger or driver's side tail light? Here's the circuit. Hope this helps. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Young enthusiast
Passenger's side. Thanks for the diagram. Are parts difficult to come by/install?
