haycait911's Avatar
weighed in the SWB today....1892 lbs
spring weigh-in of the '67 today at 1892 lbs, with a couple gallons of gas. stock was 2341 lbs so I've lost about 450 lbs. and it's at a 69/31 weight distribution. I guess that's what happens when it's a lot easier to take weight off the front than the back.
engine details here.............
3.0 dyno day - a pleasant surprise
my perhaps optimistic goal is 911R weight of 1785 lbs. about a hundred pounds to go. it's a street car so I want it to still look more or less 'stock-ish'. I have the one-year-only aluminum vented window frames coming, and an RS gas tank so that should get me about another 40 lbs or so. also working on a single vacuum operated wiper instead of the motor and linkage assembly. it gets harder all the time. I walk around the car looking at whether or not I really 'need' a part.
this lightening thing is a bit addictive. right now I'm at 7-1/2 lbs/hp, which is pretty darn good. here's a list of what I remember are the changes so far.
fiberglass lids, fenders and bumpers. (I won't put glass doors on a street car ).
lightweight fixed seats ( have you ever picked up a SWB tilt bracket?! ).
lawn tractor battery.
aluminum seatbelt hardware.
m&k muffler. ( expensive and not real quiet, but light ).
944 turbo spare rims.
lightweight steering wheel
removed stock rubber mats ( amazingly heavy ).
exhaust headers.
glove box door removed ( but kept the radio ).
rubber lid latches.
any thoughts/suggestions much appreciated. Don.
Old 06-10-2011, 12:20 AM
Elombard's Avatar
how about 911R signal lights and I think TRE does a replica plastic door handle?
Lose the headline and glue some light weight carpet up there??? maybe no wt savings. How about a simplified defrost, hose hooked to a small fan (like a race car).
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 06-10-2011, 02:17 AM
petevb's Avatar
Originally Posted by haycait911 View Post
it's at a 69/31 weight distribution...
Thoughts... uh, "Houston, we have a problem"?
I wouldn't take anything else out of the front, I'd get anything you can out of the tail (exhaust, lights bumper, etc).
When you're done with that I'd start putting things back up front until you get to around a 38/62 race balance... But that's just me...
69 w 997 GT3 3.6L
Old 06-10-2011, 02:30 AM
911-32's Avatar
Plastic rear screen and qtr windows.
Old 06-10-2011, 02:33 AM
mph911
Lose the steelies, they cant help a weight loss program.. They do look good though, as does the whole car.
Matt Hart - Instagram @the_escape_road
Old 06-10-2011, 03:04 AM
Been here a while
the sound insulation under the back deck/rear seat area is heavy, if you don't mind the extra noise, remove it, and the side panel area in the back seat.....if you want to keep the car quiet, seek out dynamat or similar, lightweight product.
Lewis
looking for 1972 911t motor XR584, S/N 6121622
Old 06-10-2011, 04:07 AM
bart1's Avatar
He said 951 spares, pretty sure those are AL. I would think heavier than Fuchs, though.
Old 06-10-2011, 05:29 AM
giovanni86's Avatar
If I were you ... I would stop ... your car look great and it is very light
Old 06-10-2011, 05:30 AM
Lighter individual air filters? Lose the rear torsion bar end caps ,balsa shift knob
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 06-10-2011, 05:33 AM
stephens_kj's Avatar
Personally I wouldn't change the rear lenses to the RSR look, the car looks much better with the original ones.
Car looks very nice, I too love the steelies look - very cool.
1983 911 SC 3.0
1978 Ford Capri X Pack 3.0
SE OM Flyer 2011(26), SE PK Ripper 2010 Retro Loop(20), Mongoose SGX 1999 Anniversary(24)
Est 1971
Old 06-10-2011, 05:56 AM
haycait911's Avatar
thanks for the input so far guys.
to be honest, I don't really like the looks of 911R signals, and would kind of get me away from the stock look. also, in fall I'll be glassing over the front turn signal holes, gives the car a nice look.
the rims are ( I think ) the second lightest 'stock' rim out there. 10.5 pounds, fuchs are around 14-15 depending on size.
I'm working on an air filter, but the usual rainhats aren't exactly light. I'm trying to adapt a plastic MFI housing to the carbs. or just run open stacks. the t-bars caps are gone, replaced by plastic plumbing caps.
lexan rear and side windows will go in come fall when I do the body. and maybe pull-up straps for the side glass and ditch the regulators.
most of the venting is gone already. also the clock and left combo gauge are gone. putting the ford dash vents in the holes.
plastic door handles are on the list.
rear seats and belts are off the table, it's still a family ( of four ) fun car.
I'v got some hood lights and will put them on as soon as I find some fiberglass headlamp covers to replace the H-4's.
I don't really want to remove any more sound deadening. it's already pretty noisy.
finally, the weight distribution isn't exactly ideal, but it's a street car. and the only racing I do is drag racing, so it's not really hurting me there.
the last hundred pounds isn't a necessity so much, this has just kind of gotten to be a hobby/obsession. my wife has pointedly suggested that I could drop 20 lbs without missing it, but that's just crazy talk. women...... sheesh I mean, if you haven't got something helpful to say, don't say anything at all.
thanks again for the input. Don.
Old 06-10-2011, 07:38 AM
rfloz's Avatar
Yikes! I'm struggling to get my car down to where your car started! Of course, starting with a 3.2 Turbo-Look doesn't help.
By the way, there are fiberglass standard rear tail light housings floating around. Try a search on impactbumpers.com.
Sweet car.
Bob F.
1984 Carrera Factory Turbo-Look
Old 06-10-2011, 08:26 AM
haycait911's Avatar
Sweet car.
I looked into those, but the SWB tailight hole is narrower top-to-bottom. the later metal housings don't fit, so there's no chance of thicker glass ones goin in. the stock SWB housings are MUCH lighter than the later ones anyway. thanks for the thought, and comment.
Old 06-10-2011, 08:31 AM
Home of the Whopper
Sorry cant really help, but I would love to see more pics and some specs.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 06-10-2011, 08:43 AM
Painted/airbrushed on signal lights and headlights a la 70's funnycar. you can use moto turn signal bulbs or sthing .just throwing ideas out there.
Old 06-10-2011, 11:21 AM
tobluforu's Avatar
Cut the exhaust tip down; get rid of the license plate holder.
Old 06-10-2011, 11:43 AM
304065's Avatar
Front suspension from 911SC with aluminum crossmember will save you a few pounds and it's a better design than the SWB.
911S aluminum front calipers
Lighter, smaller tires.
911R front and rear hinges to replace existing hinges (very heavy)
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-10-2011, 12:02 PM
loach's Avatar
Unfortunately I've nothing productive to add to what's been said, though I'd echo the sentiment that it's probably time to start taking bits off the back and adding them to the front. It's lovely to be able to limit the spins to 360 in a 911, and more than 720 just feels like showing off. Lexan rear windows seem like a good idea and if you could get vented rear side panes it would look uebercool. To me at any rate. Your rear passengers might have their own feelings about that one.
Essentially, I just wanted to post to tell you that I'm loving your work and that your car looks fantastic. Understated and purposeful. Not so artsy or fussy as an iron fist in a velvet glove... more like a hand grenade in a sock. I love it. More pics.
Edit - You're ahead of me on the lexan windows, so..... as you were. The only other thing I can think of beyond an expensive lwt exhaust is to start drilling holes in it.
Old 06-10-2011, 12:18 PM
m1franck's Avatar
haycait911, how much does the driver weigh?
Fiberglass rain hats and engine surrounds. Show us some photos of the engine compartment, so we can offer more ideas.
Old 06-10-2011, 12:36 PM
AlfonsoR's Avatar
I might be making some of this stuff up...
1. Brake mods: cross drilled rotors, lighter calipers, maybe even lighter (smalle or just thinner) discs
2. drive train: lightened axles, light banana arms (you might have those already), lightened clutch, flywheel
3. drill holes where you can in the chasis (not a good idea)
4. drill holes in engine cross bar
5. Titanium or aluminum bolts/ nuts, hardware where you can afford
6. Aluminum pulleys
7. rain gutter delete
Old 06-10-2011, 02:06 PM
