So put me on a highway
Alternator warning light problem.
1985 Euro Cab.
I am troubleshooting a no-charge problem...battery is fully charged and the alternator warning bulb is good, but bulb does not light when key is on. If I ground the bulb with the key on, it lights.
I disconnected the 14 pin connector in the engine compartment and I have continuity between the male post of the D+ (blue) and the blue wire at the Alt. warning light.
I do not have continuity from ground to the female D+ blue wire on the 14 pin connector...should there be continuity?
If so, next step is alt. removal.
1985 911 Euro Cab.
Old 01-24-2012, 06:05 PM
Rescuer of old cars
Arne2's Avatar
I had this problem a shortly after I bought my '84 a few weeks ago. In my case, it was a failed voltage regulator (which mounts on the back of the alternator).
'84 Carrera - Elect. Failure, car towed come.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-24-2012, 08:39 PM
ivangene's Avatar
+1 for VR...
easy to test that first IMO
Ed M
86' Coupe
Old 01-24-2012, 09:10 PM
clarkd's Avatar
The path to ground from the warning lamp is through the blue wire, VR, brushes and slip rings on the rotor inside the alternator. The VR seems the most suspect for your lack of continuity to ground.
Old 01-25-2012, 08:02 AM
