Stock 3.2 vacuum
Can any one tell me what a good vacuum range is? I am getting 8 inches and I want to know if that is the norm.
Thanks Joe D
Old 12-23-2011, 08:05 AM
Flat Six
Flat Six's Avatar
'Normal' varies by engine load -- idle, WOT, decel, etc. Nothing special about the 3.2 compared to other engines re: interpreting vacuum; try here:
http://www.actron.com/publish/2004/06/07/pdf_english_16176.pdf
HTH
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 12-23-2011, 08:24 AM
Looking for idle vacuum
Old 12-23-2011, 09:00 AM
I measured 2 cars (hot, idle @ 880rpm) a while back:
'87 3.2l with cat bypass (113k miles): 58kPa vacuum
'89 3.2l stock (91k miles): 52kPa vacuum
Cheers,
Mark
Old 12-23-2011, 09:29 AM
Flat Six
Flat Six's Avatar
Assuming your gauge is connected correctly, at idle 8 in. Hg suggests fairly large vacuum leak; a steady 15-22 inches would be desired.
FYI, 52-58 kPa (kiloPascal) = 15-17 in. Hg
Again, I'd suggest you take a look at the link I posted earlier, it does provide some useful diagnostic steps and standards.
Dale
Old 12-23-2011, 09:57 AM
Thank you guys will look for leaks and try another Gage . Car idles smooth.
Old 12-23-2011, 10:41 AM
arbita1's Avatar
I'm going off memory right now, but i think the bentley manual has the vacuum testing specs in it.
Matt.
83 911SC
85.5 944 NA - Sold
Old 12-23-2011, 11:17 AM
Chain fence eating turbo
Cheers,
Mark
That's around what my car does. It's good to see other cars in my range because I've been thinking I have a vacuum leak.
Maybe I don't afterall.
Old 01-28-2012, 08:29 AM
If you could find those numbers, I'd appreciate it.
To the OP, 8 in/hg is too low. You must have a leak somewhere.
All of the vacuum lines come from the back of the plenum under the throttle body. After that, there is 2 gaskets and 1 insulator per cylinder under the intake. I had 3 insulators that were crumbling.
Old 01-28-2012, 08:32 AM
I have sprayed starter fluid in all those spots and have come up with nothing. Car idles great. With or without the o2 plugged in.
Old 01-28-2012, 08:56 AM
Bump for factory vacuum numbers
Old 01-28-2012, 02:12 PM
muck-raker
kidrock's Avatar
I have read that the bottoms of the intakes may not always respond to spraying. Unfortunately, it's one of those deals where you may need to remove the intakes in their entirety to have a look at all those gaskets and spacers.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-28-2012, 07:05 PM
I thought that very same thing before that maybe the spray cannot reach down below the shroud. Good to know.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-28-2012, 08:29 PM
Just got some readings this morning @ about 50 degrees:
Idle (880 RPM) - 52 kilopascals
Off idle (1200 RPM) - 60 kilopascals
Decel - 80 kilopascals
Old 01-29-2012, 07:02 AM
