Does the Dash Speaker Grill Snap Out or Unscrew? 1974
Hi,
Before I destroy anything, I thought I'd check.
Does the speaker grill in the dash just pop out or does it need to be unscrewed from below? I've searched the topic but can't seem to find the answer.
I want to run my XM antenna wire thru that. Thanks.....
Vern
Old 01-29-2012, 04:08 PM
winter
Winter's Avatar
On my 75 it is held in by studs. I've read somewhere that you have to remove the dash to access them but since the speed nuts that hold mine are missing, a good bump is all I need.
I haven't worked on seeing if I can get up under the dash to re-attach yet, but you might be able to do this, or perhaps remove the glovebox and go in that way?
Good luck.
Tom
'76 Targa
Old 01-29-2012, 04:33 PM
