-   -   bouncy tach and no start (http://forums.pelicanparts.com/porsche-911-technical-forum/653986-bouncy-tach-no-start.html)
Sirius Driver 01-27-2012 04:19 PM
My 1982 euro is acting up. I noticed that once in a while my tach will start bouncing around. It will go to ZERO if I turn on my lights or if depress the brakes. The other weird part is that it the car will not start whenever the tach starts to bounce around. Ive left it alone for over 8 hours and no start. It will start if I push start it, and a Jump start does nothing. I have plenty of battery juice, It could be a ground but where do I start? Or has anyone have this happened to em?:confused:
KNS 01-27-2012 04:47 PM
When you say battery has "plenty of Juice" how much are we taliking? You should have 12.8 to 13 volts. It might start with less volts if everything else is tip-top.
mca 01-27-2012 05:24 PM
Voltage regulator going bad will trigger tach to bounce.
Joe Bob 01-27-2012 06:18 PM
When it bounces....see if you can get a voltmeter on the circuit. Even if it one of those cheap assplugin models.....if you see a spike in output, it's the VR.
Targalid 01-27-2012 08:23 PM
I found this little gizmo handy for diagnosing my charging system. You plug it into the cigarette lighter and you can see the voltage fluctuations while driving. My voltage would spike above 15 volts to as high as 17 volts. I replaced the voltage regulator when I saw this. Helped fix the bouncing tach.
http://www.amazon.com/Vector-VEC008-Digital-Voltmeter-Volt/dp/B0002ISEQW
Sirius Driver 01-30-2012 04:23 PM
Drove the car all weekend and couldnt get it to act up. Is the VR internal or External in an '82'?
timmy2 01-30-2012 05:03 PM
If it is external you will have this on the drivers side. Black box connected to the silver box (regulator) below in center of picture.
http://forums.pelicanparts.com/uploa...1327975348.jpg
djbrand1 01-31-2012 05:36 AM
I thought an external regulator was just piggy backed on the alternator itself?
Joe Bob 01-31-2012 06:17 AM
It does on a VW....
adamr 01-31-2012 06:20 AM
Sorry to hi-jack the thread but in the pic of ignition system, the very top fuse is for what? Mine is missing and dont know what that fuse is?
Sorry again
Adam
Sirius Driver 01-31-2012 10:40 AM
I think those fuses are for your blower motor/heater and such. Okay, I'll look when I get home. I hope its external.
timmy2 01-31-2012 11:08 PM
2 fuses for engine heater blower circuit, one for targa rear window defroster on my car.
djbrand1 02-06-2012 05:12 AM
The top fuse is for the rear window wiper, if you have one.
Gustyones 02-06-2012 09:16 AM
Joe Bob, nice avatar. Reminds me of the old band Bananarama...
