Sirius Driver's Avatar
bouncy tach and no start
My 1982 euro is acting up. I noticed that once in a while my tach will start bouncing around. It will go to ZERO if I turn on my lights or if depress the brakes. The other weird part is that it the car will not start whenever the tach starts to bounce around. Ive left it alone for over 8 hours and no start. It will start if I push start it, and a Jump start does nothing. I have plenty of battery juice, It could be a ground but where do I start? Or has anyone have this happened to em?
1982 RoW 3.0 911
1999 996
Old 01-27-2012, 05:19 PM
KNS KNS is offline
When you say battery has "plenty of Juice" how much are we taliking? You should have 12.8 to 13 volts. It might start with less volts if everything else is tip-top.
Kurt
Old 01-27-2012, 05:47 PM
mca mca is offline
mca's Avatar
Voltage regulator going bad will trigger tach to bounce.
Old 01-27-2012, 06:24 PM
RETIRED
Joe Bob's Avatar
When it bounces....see if you can get a voltmeter on the circuit. Even if it one of those cheap assplugin models.....if you see a spike in output, it's the VR.
2012 ML350 3.0 Turbo Diesel
Old 01-27-2012, 07:18 PM
76 911S Targa
I found this little gizmo handy for diagnosing my charging system. You plug it into the cigarette lighter and you can see the voltage fluctuations while driving. My voltage would spike above 15 volts to as high as 17 volts. I replaced the voltage regulator when I saw this. Helped fix the bouncing tach.
http://www.amazon.com/Vector-VEC008-Digital-Voltmeter-Volt/dp/B0002ISEQW
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 01-27-2012, 09:23 PM
Drove the car all weekend and couldnt get it to act up. Is the VR internal or External in an '82'?
1982 RoW 3.0 911
1999 996
Old 01-30-2012, 05:23 PM
ROW '78 911 Targa
timmy2's Avatar
If it is external you will have this on the drivers side. Black box connected to the silver box (regulator) below in center of picture.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-30-2012, 06:03 PM
I thought an external regulator was just piggy backed on the alternator itself?
84 911 - 88 944 Turbo S - Sold
996 Turbo
996 Cab
Old 01-31-2012, 06:36 AM
RETIRED
Joe Bob's Avatar
It does on a VW....
Old 01-31-2012, 07:17 AM
Sorry to hi-jack the thread but in the pic of ignition system, the very top fuse is for what? Mine is missing and dont know what that fuse is?
Sorry again
Adam
1980 Porsche 911 SC
2005 Toyota Altezza Jap spec (IS300)
too many boats
Old 01-31-2012, 07:20 AM
I think those fuses are for your blower motor/heater and such. Okay, I'll look when I get home. I hope its external.
1982 RoW 3.0 911
1999 996
Old 01-31-2012, 11:40 AM
ROW '78 911 Targa
timmy2's Avatar
2 fuses for engine heater blower circuit, one for targa rear window defroster on my car.
Dennis
Old 02-01-2012, 12:08 AM
The top fuse is for the rear window wiper, if you have one.
996 Turbo
996 Cab
Old 02-06-2012, 06:12 AM
Joe Bob, nice avatar. Reminds me of the old band Bananarama...
1985 Triple Black Cabriolet-ROW**Sold**
2008 Cayman S Guards Red/Black
2007 Audi A4 2.0T Red/Black
Old 02-06-2012, 10:16 AM
