Exotic Vehicles are here
Hey Guys,
About 911 Rear TB Bushings, it might look like a wild ideas, but here that I was thinking to explore: - release the TB pressure, by supporting arm and removing 1 lower bolt then loose 3 remaining bolts such a way that TB adjustment stays (or replace one at the time on longer bolts for temp use), then - insert lube, then - re-tighten 4 bolts back, so this way I do not have to deal with readjustment of the TBs and spring plates... Also, I was getting an advise to drill holes for Zerk Fittings..... I am talking about plastic bushings... Thank you for your opinions. -Youri PS: I have NOT done this, just running through you, guys, and this is NOT MINE bushings (just pic for reference), mine looks more centered.
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com Last edited by 1-ev.com; 01-29-2012 at 03:24 PM.. |
The issue I see is how do you lube the "inner" of the 2 bushings? I can sort of see how you'd get the cover at least partially off but there's no way that spring plate it going to be backed off any distance at all without disconnecting it from the end of the trailing arm and then you have to make sure the caster/camber adjustments are put back to where they were. I thought of this myself and then realized I was only getting lube to 1/2 of the problem.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
1-ev,
Couple of things 1 You are not supposed to lube the bushings at all. 2 By doing what you are talking about, you will not be able to remove the torsion from the bars sufficiently to remove the cover..
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Looks to me like the bushings need replaced. Is that metal to metal contact at the top?
Valkyrie |
TR...Op says these are not his bushings....
It pays to read the post completely. Sorry
Valkyrie |
If you have squeaky plastic bushings you are trying to remedy, fix them well by going to Elephant PB versions.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Yeah, Ed's right, I've tried all sorts of tricks and my "plastic" bushings are insanely noisy. Plan to switch them out but don't have the time or will to do that right now.
Don't need to go to the PB bushings, use the ER neatrix....the work a treat!!!
I don't think the ER economical bushings are Neatrix....aren't the rubber?
The PB are worth every penny, an excellent design. |
Home of the Whopper
Put the rear on jack stands
Remove whatever you have to so the end of the spring plate is dangling in the air Measure the distance from the end of the spring plate to the floor Remove spring plate Lube / replace bushings Install and adjust until the measurement from the ground to the end of the spring plate is the same as the before measurement Install everything else Same principle can be used to adjust rear ride height. Every 1/2" difference in spring plate height to ground is about 1" difference in ride height (approx, I forget the exact ratio)
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
At First, Thank you all guys for the quick response, I am always appreciated any help ... ![]() Following pic of my bushing, as you can see I was trying to lube it and BK911 advice looks like will work... Thank you...Just wanted to clarify that lower bolt, where arrow pointing, needs to be removed for this procedure... I LOVE Chuck's bushing, and other stuff, do not take me wrong !!! But I want to use what I have... Thank you again. -Youri
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com Last edited by 1-ev.com; 01-29-2012 at 03:20 PM.. |
