TOO RUF's Avatar
1968 911 L rear caliper rebuild question.
Does anyone know what rear calipers are on a 68L? They look like 912 rear calipers with a spacer for vented rotors. The pistons are 38mm. I tried ate part# 13.0441-3502.2 but the inner seal broke upon installation. So either I made a mistake installing or they are the wrong pieces. I just did the front brakes with no problem. Any ideas would help.
15 Cayman
93 Amethyst 964 Cab & 67 21 window VW Wife's
64 356
69 912 targa
68 911L Hot Rod
Old 01-28-2012, 05:35 PM
Call Eric Shea at PMB Performance. You have wide L calipers on the rears on the 68L.
As you said they are 38mm for vented rotors unlike the regular L calipers which were
35mm for solid rotors IIRC.
andy
Old 01-28-2012, 05:55 PM
super9064's Avatar
Check here
Early 911 Rear L-Caliper (65-69)
Old 01-28-2012, 06:01 PM
TOO RUF's Avatar
I didn't see kits on the site. Do they sell kits only?
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 01-28-2012, 10:19 PM
You may have to call. I'm certain I got kits for my wide-L rears from
Eric some time back.
andy
Old 01-29-2012, 03:10 PM
TOO RUF's Avatar
what about rear rotors, are they the same as the 67S?
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 01-30-2012, 09:52 AM
Search over on the 911S forums, there is all the info you will ever need on the '68L and S brakes.
Rear brake Factory part number kits for wide L '67-'68 calipers:
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 01-30-2012, 11:27 AM
Keepin' it Simple...
R_Builder's Avatar
Vented rears are pricey, so be ready. Look up the rear rotor upgrade/mod that can be done using 944 rotors. This is the route I took on my '68 912 chassis to get a little more braking in the rear and to have better parts availability down the road...
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 01-30-2012, 11:34 AM
TOO RUF's Avatar
Who do the maching to turn the 944 rotors in to early S Vented ones?
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 01-30-2012, 12:52 PM
Exotic Vehicles are here
1-ev.com's Avatar
Porsche Crest
Look at my signature, you will see rear caliper, easy to rebuild...
almost got rear-ended another day, driver thought that 1968 will need a mile to brake... ha-ha-ha...
My 2 c,
-Youri
"Y" <- My favorite question...
+ '68 911
+ Helping your business to get more business: http://myWWWapp.com
Old 01-30-2012, 03:32 PM
