polizei's Avatar
3.2L Carrera - PMO Carbs with Bosch Motronic or MSD?
Guys,
I'm in the process of converting my 3.2L Carrera into a twin-plugged 3.4L with higher compression. My goal is to build a performance street car that is very reliable day-to-day and fun to drive at the occasional DE. I'm interested in replacing the stock induction system with one that allows the engine to breath better and be more responsive.
My budget does not allow me to go with a fully programmable ECU and ITBs, so I'm considering PMO Carbs. Does anyone have real world experience in moving from Motronic to PMO Carbs w/ MSD for ignition? Or how about PMO Carbs and maintain Motronic for ignition? How much of a compromise is this in terms of reliability over Motronic? Does anyone know if Steve Wong will program chips for this?
I couldn't find much information on running PMO Carbs with Bosch Motronic. Interesting article here: Investigating conversion 911 Motronic with Carbs. « The Porsche Independent Repair. Here's a thread in which a few Pelicans refer to the possibility of PMO Carbs with Bosch Motronic, but no documented install is mentioned: 3.2L conversion to PMO Carbs - Ignition Options
How much time and cost is involved with installing/tuning PMO Carbs?
Thanks Guys
Andy - 1987 911 Carrera Coupe
Old 01-24-2012, 05:35 AM
ASE Master Tech - 35 yrs
larrym's Avatar
carbs will require different cams as well - you can't just bolt 'em on & expect it to run strong
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 01-24-2012, 10:59 AM
polizei's Avatar
I'm planning to change cams as a part of the build. Thanks.
Bump.
Old 01-24-2012, 11:20 AM
Chain fence eating turbo
Lets see here:
1. MegaSquirt II ver 3.57 = $272 IIRC in kit form (assemble yourself)
2. Crank trigger pulley, Ford EDIS-6 ignition system, VR sensor/bracket, wires, etc = $400
3. Various sensors = a little >$100
4. MS main harness = $70
5. Clewitt TPS = $140
Total = a little >$1000
Used, cheap Triumph motorcyle TB's and injector blocks = $??
Isn't PMO's like $3500?
Wouldn't it be cheaper to do the fully programmable EFI with TB's? I might be missing something.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-24-2012, 11:30 AM
polizei's Avatar
Originally Posted by Tippy View Post
Lets see here:
Tippy - My guess is that the cost of parts for carbs versus ITBs with programmable EFI is about the same. Installing and tuning carbs is cheaper/faster.
I'm curious to hear anyone's real-world input in converting from Motronic to Carbs.
Old 01-24-2012, 11:42 AM
AutoBahned
RWebb's Avatar
you mean converting from Motronic to Carbs while retaining the computer?
or just in general? if the latter, there are numerous threads
I would (did) twin-plug it also.
Old 01-24-2012, 11:44 AM
polizei's Avatar
Hi there - I'm interested in both, but more so in Carbs with Motronic for ignition. I'd like to understand the pros/cons of keeping Motronic.
Old 01-24-2012, 11:47 AM
polizei's Avatar
Bump.
Old 01-26-2012, 05:40 PM
AutoBahned
RWebb's Avatar
read Steve Wiener's web site - rennspeed?
Old 01-26-2012, 09:18 PM
Jeez, the L-Jetronic already gets you there with reliability, and 1.0 lambda fuel mixture. Why screw It up with carbs, unless you are talking about massively changing engine parameters and hence actually NEED carbs? What is the point of this build?
Old 01-26-2012, 09:45 PM
polizei's Avatar
I've got Motronic - not L-Jetronic. Putting aside whether carbs are right or wrong, I'd like to understand the pros/cons of using Montronic for ignition versus MSD.
Old 01-27-2012, 06:34 AM
Flat Six
Flat Six's Avatar
Don't want to speak for rusnak, but Motronic is an evolution of L-Jet and lots of guys treat them as mostly interchangeable terms since they're so similiar. In many cases (e.g., AFM, ICV) the discussions are identical and the Motronic/L-Jet distinction is irrelevant.
Essentially Motronic digitally integrates igntion and FI; in L-Jet systems they're -- well, not independent of each other -- but maybe best described as separate but coordinated.
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 01-27-2012, 07:49 AM
It's a 914 ...
stownsen914's Avatar
I didn't see if mentioned here, but some years back there was a mass flow meter mod that could be done to the 3.2 engine, that with a Motronic/DME chip and a free flowing exhaust (e.g. headers), that you could get 250 hp or more from an otherwise stock 3.2 motor. It might have been made/sold by either Welt
I also recall from Bruce Anderson (maybe his 911 book) that he mentioned that bolting 46 mm Webers, headers, and megaphones on an otherwise stock 3.2 Carrera motor made like 260 hp at 7000 RPM. I remember being impressed with that. This was back when Webers were still in production and relatively cheap, while was very expensive, of course.
Edit - FYI, just noticed a thread over in the Engine Rebuilding forum mentioning the mass air flow mod.
Scott
Last edited by stownsen914; 01-27-2012 at 08:48 AM.. Reason: added new info. on MAF
Old 01-27-2012, 07:51 AM
Flat Six
Flat Six's Avatar
Rennsport Systems (Rennsport Systems | Porsche Performance Systems and Support)
Dale
Old 01-27-2012, 08:50 AM
MBruns for President
JeremyD's Avatar
My single plug 3.4l - motronic pulled 287hp and maintained diveability - what about smog in PA? Big cam won't pass smog - so what would be the point?
Oh Dyno we will go...
my 3.4, in blue, compared to Ralph's 3.5, in red, compared to a bone stock 88 3.2 with a euro premuffler and stock chip, in green.
Old 01-27-2012, 09:00 AM
"motronic pulled 287hp and maintained diveability"
Graph shows 244hp; not 287hp
Tell it like it is or don't tell it at all.
Old 01-27-2012, 10:28 AM
JeremyD's Avatar
244 at the wheels
244 at 15% diveline loss - 244/.85 = 287
Old 01-27-2012, 10:34 AM
My bad; I always thought we looked at RW numbers...
Old 01-27-2012, 11:35 AM
polizei's Avatar
Originally Posted by JeremyD View Post
244 at the wheels
Jeremy - I'm curious to hear more about your build. What displacement, compression, cams and induction are u running?
Old 01-27-2012, 04:34 PM
polizei's Avatar
244 at the wheels
Old 01-27-2012, 05:21 PM
