dcarlson's Avatar
Angry Something fell inside my door
sounded like a snap and then something definitely fell inside driver door when I started to lower the window and then abruptly changed directions to close it. auggh. anybody have similar experience or have idea what it might be?
Old 01-31-2012, 08:14 PM
steely's Avatar
Did it sound big like a bracket or maybe something a little lighter - like one of these bad boys?
This looks like the pivot that holds the spring in the center, but this is actually is the pin that holds the spring tension on the other end. It is just press fitted in and they fall out.
Remove the panel and take a peek.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 01-31-2012, 08:36 PM
Wine User
warner53's Avatar
What is this - found laying in the bottom of Targa door?
When it occurred during window winding (or not), it could be the window winding clock spring anchor pin that fractured. Without it, the side window gently falls downward on its own. Does that sound close?
Remove the door panel and fish along the lower door area. It's a cylindrical piece with a slot cut in it (might be in two pieces now). Save it to match with the proper replacement piece. Refer to the parts area here.
S
Old 01-31-2012, 08:39 PM
dcarlson's Avatar
thanks guys - making notes for when I can at the door panel and have a look. Sounds like a common problem - quite a bit out there on the topic.
Old 02-01-2012, 03:37 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Yeap, window regulator pivot.
If you have a motorized windows, you want to change/fix sooner than later it will strain the motor
'85 Carrera Targa
PCA/POC
Old 02-01-2012, 04:10 PM
