Tons of threads on this...
Yes, its a bit scary balancing the engine, but I have had no trouble so far. The key is making sure it is well balanced and you can do this by lifting it an inch or so off the twin stacks and then trying to tip it off the jack. It is actually pretty stable if you nail the balance point. I have also used a motorcycle jack, but it is hard to get it high enough. Some day I may break down and buy an engine hoist... but for now this method has worked well for many pulls/puts. -Michael |
Engine hoist with engine stand adapter mounted to engine. Raise motor, install remaining parts of stand , lower, get to work...:)
Worked for me working alone on mine. |
| All times are GMT -8. The time now is 04:14 PM. |
