911scdave's Avatar
Clutch question
Hi Everyone im new to pelican parts and this is my first question of maybe many.
I've owned my first porsche now for 5 months a 911SC convertible 3ltr 1983. After 2 months of owning her my gearbox locked up on me, apparantly the 2nd gear syncro broke up and has done quite a bit of damage, 2nd and 3rd gear sets, hub, and sliding sleeve, its in a gearbox repairers now and i've had good news this week i should have the box back next week so looking forward to putting her back together. im a novice with the spanners but wanted to remove the engine and gearbox because of costs and i had read some much about the removing of it i thought i could do it myself, which i did with my son and really enjoyed doing it.
My question is.... in the manual it says i should make up 3 spacers and fit onto the 3 rivets on the clutch pressure plate before i will be able to remove the box from the engine well i didn't do that, to be honest i didn't understand or see what it meant, after a couple of pulls the box easily came away, do you think i will have a problem pairing them back together. the clutch is a Sachs clutch set.
Many thanks in advance Dave.
Old 02-08-2012, 01:32 PM
schumicat's Avatar
I have no idea what the spacers are for but I don't think anyone does it that way.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-08-2012, 01:45 PM
Mo money = mo parts
What manual are you referencing? Are you talking about the throw-out bearing shims? I don't what other spacer you might be referencing.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 02-08-2012, 02:46 PM
Oh Haha's Avatar
Can you post the manual and page you found that info?
The only shims/spacers I know of at the gearbox is the TO bearing set.
Pacific Blue
Wayne
Old 02-08-2012, 05:00 PM
