Please help me with my ride height
I have a 1978 SC Targa and the rear of the car was sitting very low. My mechanic and I raised the rear by adjusting it by 1 spline on the rear side of the torsion bar. It did raise the car but it raised by about 4 inches. That is definitely to much. I only needed about a 2 1/2' raise. Is there another way to adjust the ride height in smaller increments?
Splines on both ends need to be turned to get smaller increments.
For instance, if one spline was turned on the outside, the inside needs to be turned the reverse direction. Since there are a different number of splines on the inside vs. the outside, it allows adjustments in finer increments.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
I'm with Hodgey. Something is a drift or in a bind. If this is the case would two splines get you full travel? I bet my 72' doesn't move 4" total wheel travel. Rob is completely correct, but I still feel something is wrong. There are calculators on this site that can help you do this with a simple protractor and knowing TB's and weight of rear. Do you have adjustable arms?
Good luck
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
Yes I do have adjustable arms
Insert Tag Line HERE.....
bump for help
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
As Pete's link shows, go to Harbor Freight, buy yourself a magnetic angle finder. Punch the weight of your car, torsion bar thickness, and desired ride height and the angle calculator will tell you what spring plate angle to set your car. Can easily be done in one's garage without the help of a mechanic.
To change the angle in small increments, as said above, you rotate one end clockwise and the opposite end counter clockwise, or vice-versa. When you do one side, the method clicks, and when you do the other side, it takes like 5 minutes. |
Or just get the free iPhone app...
Thank you very much guys, I think I figured it out, I simply have to adjust the splines on the other end of the torsion bar that has smaller incriments and will give me the adjustment I need. Again my felloe Pelicans showed a true interest and thats great.
THANK YOU ALL!!!! |
+ lurking - contributing
What is the condition of your control arm bushings? I frequently see rear squat due to these being worn out. Plenty of choices in replacements. It's best to adjust rear ride height with a fresh set installed.
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
Did you get it to work? IF so you owe us a picture
