1987 Carrera
Tire Pressure
I have an 87 911 with Pirelli PZero Nero tires on them. The "max pressure" says 53, but how much should I put in there?
I'm just cruizing around town, not racing or anything. I push the car around the corners every now and then.
Also, is there any relation to tire pressure and noise in the cabin.
Thanks!
Ace123
1987 Porsche 911 Coupe
Old 02-03-2012, 02:53 PM
John W
I run 29 in front 36 in rear. My guess would be lower pressure / softer tire would be quieter.
John
89 3.2 Targa 123k miles
Old 02-03-2012, 03:07 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks!
We have the very same configuration on 7" and 8".
I run 29F & 36R.
A good compromise for ride comfort & wear.
Although, the PZero Nero have a very high (numerical) wear index.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-03-2012, 03:10 PM
1987 Carrera
Thanks il give it a try. 29. 36. Sounds good!
Ace123
Old 02-03-2012, 10:27 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
I always went with the old method.
Roll the tire (wheel on car) onto a dollar bill placed in front of the tire so that about 1/2" of the bill is captured by the tire.
Inflate tire until you can move the bill....then deflate about 5 pounds (the bill should be grabbed again).
Take a pressure reading....record it...this should be your best pressure for THAT tire.
Not all wheels will be the same (on my car I have 4 different pressures because I have a friend sit in the car as I do it...he weighs the same as me).
This should give you maximun contact with the road...but not have underinflated tires.
You can also (after a few thousand miles) see the wear pattern of the tires...bare in the middle=too much pressure....bare on the outside edges=too little pressure.
Bob
Bob Hutson
Old 02-03-2012, 11:32 PM
dshepp806's Avatar
Recco'd tire pressures located on inner door tag....it's 29F and 36R for me, too.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-04-2012, 07:03 AM
1987 Carrera
Interesting. Old school is a good idea. I didnt know about the door panel. I have more wear in the middle of the tires. I guess I should take some air out.
Ace123
Old 02-04-2012, 08:58 AM
Taking it apart is easy
Jerome74911S's Avatar
29 in front and 34 rear, not 36, is most often recommended. Tire noise may be affected by pressure, but tread design is a bigger factor.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 02-04-2012, 09:25 AM
Tire wear.
Center tire wear, due to the rear engine configuration, is an issue that has, over the years, plagued many 911 owners.
After 30 years of 911 ownership, the 29/36 with regular monitoring, has served us best.
Also, when checking tire pressures, I always add an extra 3-5 lbs, let the car sit overnight, then remove the excess as driving the car just a few miles can add 3-5 lbs in tire pressures.
Good luck,
Gerry
1986 911 Targa.
Only in L.A.:
Old 02-04-2012, 09:43 AM
dshepp806's Avatar
Yeap,..those recco's are COLD pressures. As stated , on my '89, her door reads 29/36,..I consider THIS the "reference" (to adjust "from")......
Aside, I keep 2-3 gauges (types) around to make sure I'm not trusting an erroneous gauge,..just to doublecheck the gauge every-so-often.
Best,
Doyle
Middle Georgia
Old 02-04-2012, 09:52 AM
AutoBahned
RWebb's Avatar
if you guys will change to 32/34 you will get a LOT better handling
P AG did things to the later cars to dial in more understeer over the years, as their customer base became less competent, and were no longer "drivers of a special breed"
Old 02-04-2012, 11:44 AM
Nine17's Avatar
After a lot of playing around (I have a compressor, retractable air hose, and racer's gauge), I've found with my current set of Kumho Ecsta SPT's (205/16 and 225/16 on 7's and 8's) that 36/40 is my sweet-spot. Modern tires seem to like a bit higher pressures than were recommended when our cars were new.
'88 Carrera Coupe G.P. White
Old 02-04-2012, 01:15 PM
80-911SC's Avatar
I agree with Nine17 the newer tires make a difference .. my Kuhmo Ecsta Le Sports like about 35f/38r ... I drop them a bit for AX but only when they get hot and raise themselves ...
Old 02-04-2012, 01:26 PM
Large Registered Member
PatrickB's Avatar
I run 32/33 HOT.
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 02-04-2012, 03:52 PM
Diss Member
Quicksilver's Avatar
The earlier cars had 29/34 on the doors and the heavier, later ones have 29/36.
As far as what tire pressure to run...
Currently I run 24 front and 31 rear cold pressures for dry grip. That works out to give me a well balanced car with maximum grip. What does that tell you? Not a whole bunch unless you have the same tire in the same sizes with the same t-bars on the car and abuse the car to the same level.
Start with what's on the door and that gives a starting point. If you are serious about wringing out the car you will need to start experimenting. With a conventional treaded street tire your maximum grip will usually be at higher pressures (often much higher). With minimal tread and/or 'gumball' R compound tires the max grip will generally be with lower pressures. Adjust the pressure on one end of the car so you can see what the changes do to the balance of the car. Start on the end of the car with the least grip and adjust till you see what direction to go.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-05-2012, 04:57 AM
