Dublinoh's Avatar
Which paint To make repro fuel tank look stock?
Hi I have a 1987 Carrera, I need to replace the fuel tank with a reproduction and would like it to look stock again. I have searched this and get more confused the more I read. Repros are bare metal I believe.
Can anyone list a selection of products that would protect from rust and have close to the stock texture and color (rattle cans would be easier for me)? A DIY on this subject would be very helpful.
Old 02-05-2012, 08:12 AM
911 carrera 3.2 (1985)
kees's Avatar
Wurth Stoneguard SKS
Old 02-05-2012, 08:23 AM
Dublinoh's Avatar
So no primer?
This material is textured?
Same color as stock inside the front hood?
Can paint darker sealer or paint under the car to match?
Old 02-05-2012, 08:31 AM
Paint and body forum
They have a good description with lots of pics for gas tank repair using this product and matching the color
Old 02-05-2012, 08:38 AM
al lkosmal's Avatar
+1 on Wurth Stoneguard SKS...............It is textured and you can buy it in rattle cans. The grey color is a good factory match for the tank. the black is a good match for the undercoating.
Note: Once it sets up, the finish can be painted if required.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 02-05-2012, 08:45 AM
GaryR's Avatar
Send a message via ICQ to GaryR
This was done using the Wurth product with a Shutz gun --
It actually fell off the drying rack after it was dry, marred it up a touch but that stuff is tough!
Gary R.
Old 02-05-2012, 08:54 AM
al lkosmal's Avatar
Wurth
Rattle canned with Wurth
RGruppe #669
Old 02-05-2012, 09:11 AM
First clean the tank with degreaser. Then red scotch pad the tank using, POR15 Metal ready, PickleX20 or a similar product to eliminate surface rust. Spray the tank with Either SEM Rustshield, POR15, Epoxy primer or something similar for long term protectiuon. Spray with Wurth SKS for the final texture and color to match OEM look and feel.
Old 02-05-2012, 10:07 AM
kees's Avatar
+1
Old 02-05-2012, 10:10 AM
Dublinoh's Avatar
Thanks to all of you, I think I have a handle on it now
Old 02-05-2012, 11:39 AM
