rear control arm replacement on 76 911sc
Guys,
Anyone have replaced one without the need of special tools? I bought my 76 930 look w/ bent control arm and can't get to align due to camber toes. I bought a used control arm w/ new bearings. I need to figure out how to press the old bearing out and swap the brakes hub and install it in the car. I read up but it look like you may need special tools. Else, anyone can refer to a reasonable price shop in the zip of 95035 w/in 30 miles radius? Thanks for everyone input. Nathan |
Nathan - you don't have 930 control arms, so the bearing replacement is much easier and can be done with home built tools. Sorry, can't offer any help on a local shop for you.
Josh 85 M491 Coupe - "Fat Bastard" |
Some CarQuest and Napa auto parts stores offer this service. They will be happy to remove and press new bearings in for a small charge, even if you have purchased them elsewhere. Call around.
George E. www.autoinno.com www.AIRMotorSports.com |
Sharky:
Try using the search function on this forum. There was a fellow Pelican from Idaho whom did all this work and also posted a write-up. I think the guys Pelican "handle" was Tom (something). Basically, he was having trouble getting his bearing to remove from the arm, so it was a long thread here in the technical section last year. Hope this helps, and, "welcome."
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
Here is another one: Better too because Gunter shows you what tool he fabricated to make this all work. Pretty cool stuff.
Here's the link to it on this site: Wheel Bearings, rear DIY
Thanks for everyone help and pointer to take the fear out of the uncharter territory for me. I always had this hesitation when I am not familiar with the process. I had to do a power window and power lock swap on the same '76 911. It take 2 months to think about it and one day to do....hmm...go figure.
Nathan |
