yama1's Avatar
Tips - Cool Cyl port cap and stud removal tool
Just thought I would share this cheap very effective cap for plugging your intake ports while removing studs or other work to keep all the Uh Ohs from happening.
This works on the 2.7 cylinder head with 32mm ports. I had always just used rags to stuff them with, but this is clean and a perfect fit.
I found that the valuecraft carb/choke cleaner caps found at Autozone work best, due to the fewer ribs for flexibility. The brake cleaner ones do notwork. These can be installed flush and they will fill the bung hole believe it or not. I just use pliers to remove.
Intake removal tool worked like a charm, but destroys your studs.
85 Euro 911 carrera
77 911 widebody coupe
"Drive the Ride"
Old 02-05-2012, 07:07 AM
If it works like a charm, why does it destroy your stud? The much more expensive SnapOn collet tools preserves your studs. They even had an very cool install tool as well.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-05-2012, 07:45 AM
yama1's Avatar
True, in my case I was replacing with longer studs. The collet machinist tool is even better, especially if you need to save them.
Old 02-05-2012, 07:57 AM
