jsmarcus's Avatar
Red face HELP! In the middle of a project....
I need help.
I have the tie rod tube off but can't get the inner tie assembly off. Any ideas?
Also, how do I remove the outer without having to go buy a tie end removal tool?
Josh
Black on Black '84 Carrera
Old 07-28-2001, 10:11 AM
maxnine11's Avatar
Post
there is a special tool for taking off the inner tie-rod, but you can try a punch to turn it off by hammering. You can split the outer tie rod end off with a pickle fork, but you'll ruin the rubber boot, and you'll get an absolutely sickening feeling in your stomach as you beat on it; swinging a 32 oz. hammer towards your porsche. Your car will be telling you " get the $39 puller you cheap #@**@!.... later, MAX.
Old 07-28-2001, 10:22 AM
jsmarcus's Avatar
Post
I need some more suggestions on pulling the inner tie rod. The outer I'm using the tool for.
Josh
Old 07-28-2001, 10:36 AM
Post
A big flat bladed screw driver and a rubber mallet should work. See the how-to in the technical articles here on pelican. I did it exactly as the instructions stated and it was fairly easy. Be sure you are rotating the ring in the right direction.
Old 07-28-2001, 12:05 PM
