86 Carrera Cabriolet
993 17' wheels on a 86 Carrera
I came across a set of 993 17' wheels at a ridiculously good price and want to put them on my 86 Carrera. Any advice on exactly how to get them to work?
You'll need adapters somewhere between 1.5" to 2".
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Adaptors meaning spacers? To clarify: I need to buy the spacers stick them on and the tires are ready to be installed?
Depending on the wheel offsets, you will need 1 inch spacers for the front and 2 to 2.5 inch spacers for the rear. Unless you install longer wheels studs you will need to get spacers that are bolted to the existing wheel hub. The "993 wheels would then bolt to the spacer using the factory lug nuts.
It can certainly be done but the spacers could cost you a few hundred bucks.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
While they look like an upgrade visually, and may be a good bargain - they are like lead ankle weights for your 911 and will substantially impact performance...you will definitely be able to tell you added all of that unsprung weight...and like many others once the look wears off you will try to find lighter alternatives.
I would invest the money in a lighter weight option. My 02.
Jeff |
FWIW, I love the look (I presume these are the rims you're considering?)
![]() Cheers, Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
if they are 55mm ET wheels, you need 1.25 spacers in the front and 1.5 in the back.
if your car is low, you will need to roll your front fenders. ![]()
Tru6 Restoration & Design |
Paul and Shaun...can you post offsets/widths and spacers ?
I would very much like to know
Ed M 86' Coupe |
Not my car, unfortunately...
My '87 cab came with what appear to be the same wheels at in Paul's pic and they were 17s. This was before I really understood all the issues but they did, on occasion, rub on the driver's side front wheel well. Typically on right turns with some sort of bump. It would hit on the rear lip. Rears were fine. They looked good and I really liked the wider rear wheels.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
hope this helps!
The wheels are the same as on Paul & Shaun's cars. Great looking cars, btw.
So I need to order 1.5 spacers for the back & 1.25 for the front. I assume I can install them myself? My car has not been lowered, it is stock, but what does 'roll the fenders' mean & involve if I need to have it done? Thanks. |
