Czar of C.R.A.P.
dfink's Avatar
My new lexan grill
A picture of the new grill I made for the rear deck. I kind of bar-b-qued the old one. Made this on a homemade cnc machine. I think it came out OK.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 02-04-2012, 07:57 PM
Member 911 Anonymous
DRACO A5OG's Avatar
That sure is pretty, have you tested the air flow?
'85 Carrera Targa
PCA/POC
Old 02-04-2012, 08:02 PM
Czar of C.R.A.P.
dfink's Avatar
Haven't tested air flow but it should be ok as the grill also sits up a bit all the way around the outside of it. It is probably not much smaller area that what was there before as the old grill had a mesh design between the ribs. If need be I left room for a couple of holes on either side of the porsche letters. There is also no seal around the rear deck so air can also get in there.
66 912 Coupe
Old 02-04-2012, 08:13 PM
It's pretty. I think you are seriously restricting the airflow the the carbs and fan. I guess if it doesn't get hot and runs ok then it doesn't really matter.
-Andy
Old 02-04-2012, 08:14 PM
Czar of C.R.A.P.
dfink's Avatar
There is about 70 square inches of open grill not counting what goes around the outside. On most cars there is an evaporator stuck there also restricting flow. Will have to see how it works.
66 912 Coupe
Old 02-04-2012, 08:23 PM
Danny_Ocean's Avatar
Will you be producing these for sale? I'd like one with round holes, kinda like you see on the floorboards...
Old 02-04-2012, 10:11 PM
Racer
winders's Avatar
Danny,
Is that your car? Where did you get the gas pedal?
Scott
Old 02-04-2012, 10:16 PM
mixer911's Avatar
Wow thats really creative,now You need something that lights up at night,makes a great viewing port.
IT does look professional and modern.
Old 02-04-2012, 10:24 PM
Originally Posted by winders View Post
Danny,
Scott
No, not mine. I Google'd "Porsche Drilled Floorboard" to get the example pic.
Old 02-04-2012, 10:34 PM
Czar of C.R.A.P.
dfink's Avatar
No plan to reproduce. If all you want is holes a jig saw and drill should do the job just fine.
As for the lights it would look kind of neat on a honda streat car but this one is an XP autocross car. The rear grill was not really made for pretty it just came out that way. I fried the original plastic grill in a engine fire last year. For the most part the only damage. I was going to smooth out and sand down the original grill but a piece broke out so I just decided to make this. I was going to paint it black but figured paint wouldn't stick well anyhow so just left it clear.
66 912 Coupe
Old 02-05-2012, 07:26 AM
Wash. State
nesslar's Avatar
-Andy
Hard to say, but a neat piece. I thinking going 'all horizontal' at the sides/ends (though I didn't show that here) maybe, and adding more slots (shown), $.02. Hope a certain company doesn't mind the idea... Nice work.
Old 02-05-2012, 08:22 AM
ivangene's Avatar
I seriously doubt there will be a lack of air... nice job!
BTW...for laxan if you put a small radius on the cutter and use WD-40 liberally the finish will be clear as opposed to white chalky... for the slots, run down the middle then climb cut the slot edges for a nice finish - sharp sharp sharp tools work best in plastics as they create less heat and therefore less burning/melting.... in case that is of interest to you...
Ed M
86' Coupe
Old 02-05-2012, 09:31 AM
Czar of C.R.A.P.
dfink's Avatar
Thanks for the cutting tips. I am totally new to the CNC machining world. Built the router originally out of wood as an internet DIY then converted it to 1" steel tubing. I don't have alot of tooling for it and only have EMC2 and an old autocad 14 for software. So when I get anything useable I am happy. But tips like yours really help.
66 912 Coupe
Old 02-05-2012, 11:18 AM
Porsche Owner
mark4ton's Avatar
what about flaring the vents to be more of scoops.
1987 Carrera - 2008 Cayenne Turbo
Old 02-05-2012, 11:29 AM
I think you are seriously restricting airflow into the engine compartment. The fan that cools the engine pulls a very large amount of air through there!
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-05-2012, 01:17 PM
DUK DUK is offline
DUK's Avatar
Yep, tried something like that once. The temp light went off all the time as well as my afr's went crazy. Something to be said for mesh and helping air flow not hindering it.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 02-05-2012, 01:22 PM
super9064's Avatar
Makes me hungry
Old 02-05-2012, 01:43 PM
ivangene's Avatar
even if it fails - cool and better than sitting on your a$$ watching football
Ed M
86' Coupe
Old 02-05-2012, 03:14 PM
kugelfischer's Avatar
Very subtle. Haha.
Originally Posted by super9064 View Post
Makes me hungry
1973 Coupe
Projekt X (AKA bunch o' boxes full of parts)
Old 02-05-2012, 05:42 PM
I hear ya ed, and totally agree with you... Stinking football. Tim
Old 02-05-2012, 06:09 PM
