+1 long trips=Turbo
normal fun =SC Unless you get a 964 or newer Turbo which is really the best of both worlds. 5spd or more, great a/c, very little lag, very quick and oodles of power on the hwy. I had an 81 930 and my 91 is sooo much better. Even though not quite as brutal and quick. |
In the late 70s I saw in person every 930 engaged in the 24 hours of Chamonix on ice being eaten alive by the Peugeot 104-S, simply because the rear wheel power of the 930 was unusable on the icy track vs the front wheel drive lightweight 104.
So what I am saying is that there is a car for each purpose, and the 930 is no exception. I still wouldn't mind owning one!:D |
I don't understand the problems some people say they have with these cars (930) in traffic/commuting - the long gears mean much fewer gear changes and the power means with just a light touch of the throttle you are scooting down the road in a hurry . . .
I drive my 930 at least 3 or 4 times a week and mostly in everyday traffic... I LOVE it and would happily drive it everyday but I'm careful about where I take it (parking etc)..
I have the 89 5 speed but with a 964 Turbo motor .. K27 7200 Turbo I went for a drive through the mountains with a friend in his 82 SC and he just couldn't keep up .. The extra power was there when required so if I had to overtake I knew I could do so safely etc .. When I was looking to buy it was always going to be the 930 - just so happens that the exact car I wanted came up at the right time ... |
I have a 78SC, and I run with a few 930 guys. I have spoken to them at length about the cars as I do want to get one, one day. Here is what I have gathered.
They are amazingly powerful there is no question there. The maintenance is more, not per say more often but larger in quantity. There simply are more moving parts that have to be cared for, that is true for all turbo engines. That being said the SC with its CIS has plenty of its own issues. I have never seen a bad condition 930, every one I have ever seen either in person or for sale has been in great shape as any one that owned them cared for them and did it right. This plays out nicely as in many cases they seem to need less work but that tends to be because of how well they were cared for. IMO it boils down to use. If you are a suburban rally car driver (as I like to call my self) making the best of the back roads by your house, and the drive to the grocery store, the SC will give you more than you will know what to do with. I would genuinely be afraid to unleash 350HP on the back roads by my house. That being said im sure it would be a blast. I know many people that drive them very often just like there SC's in the end of the day a well cared for car will work, that's that. It all comes down to application, you would not use an F-16 to crop dust(with in reason), and you would never fly a small prop plane in to battle. Though they would both function for the task, the right tool is the right tool. Regards Dave |
Thank you, gentlemen! I appreciate each of your responses very much. I've been looking for an sc for quite some time now, but I have always been attracted by the sexy and powerful allure of the 930. For the 1st time, I am expanding my options. I was recentky admiring an m491, but came to the conclusion that this body style should really be coupled with a turboed engine. I just love the 930's wide stance and muscular curves paired with the turbo-weapon. As for driving goes, I'm only interested in occasional spirited rides(not spirit-producing!).
Thanks again, Porsche bros! Kurt |
Another point is that a 930 isn't much more expensive to own than a 911. It takes longer to do a valve adjusment but it's not like you do those every month. The brakes are more expensive to replace but they last a long, long time. A typical 930 that sees just weekend use won't break the bank. JR |
Aesthetically speaking, it comes down to the difference between a B-cup and a DD-cup.
I can get in more trouble than I care to "speed wise", in my 3.2. Turbo for me, would be trouble. Tim
For me the ultimate (which i sadly discovered after purchasing my narrow body) is the M491 with 350 hp, naturally aspirated engine a la PMO carbs and rear wing delete.
The 930 may very well have more torque (just speaking below 2500 rpm), but the taller gearing and heavier weight pretty much negate that when taking off from a stop light.
I have owner my SC for almost 20 years, and have a bit of seat time in 930's. I personally don't think the 930 is a good driver, and just plain sucks in autox. I'm not saying its impossible as a daily car, but it does take some seat time, and trying to drive fast in the rain would be a bad thing. I think the service issues come from the fact the motor is hot all the time, and you have to keep the revs 3k all the time. I was just driving one last week down the frwy and it never seen 3k in forth gear. I also wouldn't just hand the keys to a 930 over to just any old smuck. I think there was a good reason they stopped importing them to the US for many years. OtOh: the 965 (964 turbo) is much more drivable and would be my choice if I had to drive one every day. But it can still get you into trouble if your not on the ball. |
I have both a 77 turbo and an 83 SC. I just got the turbo in August.
The turbo has a 915 in it. When its time to drive anywhere, I will pick the turbo every time. Some have suggested the turbo is ugly to drive in traffic, that is not true with the 915 in it. It seems about the same to me as the SC off boost, and boost is addictive. The turbo gas mileage is 13-18, the SC is always 20-22. |
If I remember correctly, the 930's engine is set a couple of inches more to the rear than those of the naturally aspirated cars, further screwing up the f/r weight bias. It's why you have to be so careful to prevent off-throttle snap oversteer.
I've only driven early ones, but from what I recall, they come on boost quite suddenly. You really have to be careful with the things. One final thing, in reference to this comment: Quote:
The off-throttle oversteer issues are overblown. You'd have to be a pretty lousy driver to get into trouble with that one and a 930 isn't worse than a 911 in that regard. What's more of an issue is understeer when coming out of a corner on the power, which also is something that a 911SC or Carrera does, to one degree or another.
A 930 gets to operating temperature just as quickly as a 911, so I don't know why that's an issue. In warm weather, it takes nowhere near 15 to 20 minutes in either car. The onset of boost can be managed as well. Changes to the exhaust, turbo, etc. can give you something different than stock and anybody that drives a 930 long enough can modulate the throttle during the boost transition to make it less abrupt. What it comes down to is easing out of the throttle somewhat as the boost starts to build. Any abrupt transition comes from being hard on the gas at low revs and keeping your foot planted as the boost builds, something that nobody that I know does. It's not a particularly good idea to be at full throttle well below the torque peak for any 911 or 930, so if flooring the throttle at 2000 rpm is considered normal for some people, then maybe they need to rethink things a little. A 930 responds well to a driver that anticipates things a bit, which is also a good thing in any other car. Lots of things that a 930 does "poorly" have nothing to do with the car and everything to do with the bad driving habits that some people have. I'm not trying to rag on anybody in particular, it's just that maybe these cars are less tolerant of bad habits than others. In other words, don't blame the car... One thing I will agree on is that they are lousy in an autocross. But, a lot of autocross courses tend to be too tight for any car. The one at the '83 Parade was nice... JR |
I have owned a 1986 Turbo, 1984 Carrera, and currently own a 1987 Carrera. I loved them all when I had them...but the 930 is sluggish or hauling ass and not much in between in my memory. It just wasn't that exciting until you accelerate through 80 mph plus on boost, then it is amazing if not street legal. I always attributed this "off or on" characteristic to the four speed (was I right???). Not much argument that the 930 is one of the best looking Pcars ever.
JR |
I ran the '86 for years, bone stock, then modified it like most other US cars (cams, turbo, exhaust, intercooler, etc.) and either way, the ROW car was easier to drive. Oh well... JR |
| All times are GMT -8. The time now is 11:38 AM. |
