Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Freeplay in front shock
I have koni shocks, of the knob less adjustable kind. Recently i noticed that the front right wheel has about 2-3in of vertical freeplay before resistance is felt.
Is the shock shot or could the adjustment be "loose" ?
Old 02-08-2012, 02:29 PM
Max Sluiter
Flieger's Avatar
The spring comes from the torsion bar, not the damper. If you are saying you jack the car off the ground and there is free play, that is normal, as the torsion bar anchor points on the crossmember are not fixed, they just use bolts resting on the crossmember to set the ride height (you can see what I mean if you look down there).
Old 02-08-2012, 02:32 PM
Banned
I see what you mean. I'm gonna give a look.
Old 02-08-2012, 02:37 PM
