jphillips-998's Avatar
Help with MFI
I have a '74 Euro Carrera with the type 83 (RS) engine. Recently brought it back from Denver, CO to Illinois.
My problem/question is does the MFI need to be adjusted to the lower altitude? Very rough start up and significant delay on acceleration. Usually have to play with the throttle to bring the power on. Also quite a bit of backfiring even when fully warmed.
If it is an MFI adjustment do I go richer or leaner and how do you tell when it is correct?
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 04-14-2002, 10:07 PM
Automotive Writer/DP
Randy W's Avatar
MFI has a barometric sensor built in that leans at high altitudes and richens the mixture at lower altitudes. That said, they don't always work correctly due to age. The best way I've found to tune MFI is to take it to a load dyno with an exhaust analyzer and adjust the MFI rack there.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 04-15-2002, 05:31 AM
