'77 Carrera 3.0 Targa
Fitting a passenger side mirror on a '77 911?
I'm about to buy a 1977 911 - they did not come with a passenger mirror as standard, but I want to fit one. It think the guy has one for me, but I have no idea what is involved in fitting it. it it just a simple few holes drilled and screwed into place? I won't be doing it myself but is it a quick job?
Thanks |
ASE Master Tech - 35 yrs
it mounts in a slightly different position than the driver side, templates/measurements were published long ago in Pano, it also should have a reinforcement piece on the inside to keep the door from cracking
all factory '74-89 flag mirrors are identical as far as i know, and some parts are still available from Pelican, but complete assemblies are only found used i do have one used right side mirror FS complete with template & NOS reinforcement part that i b'ot from E.A.S.Y. and never installed cuz i sold the Targa (i paid $200 for it plus tax & ship) I will sell it shipped free USA for $150 - USPS Priority mail medium flat rate box - it is white, rubber is OK and glass is OK; you would need to get a new base gasket from Pelican I also have a PAIR of electric mirrors from an '80 SC - complete with wiring and switch - (in primer) - offers considered - PM .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Passenger side mirror mounting template.......
The instruction and template is available in the Porsche shop manual. PM me your email address and will forward one to you. It is a few minutes job and a lot easier if you know where to place the mounting holes. The guide or template would do the trick. Tony |
Check to see if your passenger door has these plugs. My car is a '74 (same body as yours, probably different mirrors).
My passenger side mirror is about 1 inch closer to the rear of the car than the driver side. I have no idea if it was installed at the factory or prior owner. I do know that on my 914, the welded nuts were there by the factory and I only had to drill holes to access. So, maybe a 911 is a similar situation. ![]()
Tidyboy is offering incorrect information ! The passenger mirror mounts in a different location further aft, about midway in the fixed glass of the door frame. Why? You sit on the left side of the car and if mounted the mirror further forward , you won't be able to use it.
Check the other posters' information regarding a template. You will have to remove the passenger side door panel , to place the inner reinforcement plate. Wiring? its about an 8 hour job to remove and install all the looms- a driver door mirror harness is different than a two mirror install. So keep it manual
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Banned
leave it be. you will appreciate the uniqueness after a while...
I would use the template if one is available. My car might not be in the correct spot (as I mentioned it was on the car when I got it). However, I see thru it perfectly without any obstructions.
Thanks for the replies guys. The car is a Carrera 3.0 - and its right hand drive. I'm going to see what the guy says who I'm buying it from. he's just finishing it off and I'll have it in two weeks!
I thought of doing the same to my 79 targa. It also came originally with only the driver side mirror. The other mirror really is not necessary because of the excellent visibility out of my Targa window. For a good passenger side mirror installation you need a good reinforcement inside the door panel. And then you want the electrical wiring of course. Otherwise the mirror is hard to adjust correctly. You also have to add a mirror selection switch to your driver door. Its a lot of work. And I think it's mostly for outside cosmetics. That's why I gave up on it. On the other hand we are unique:
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
1977 911 2.7 Stock restoration in progress |
Zuffi-Freund
Hello Henrik,
chrome mirrors won't fit on your 77 without modification. You will need to fit in an adaptor or do some welding...
******************** best regards Heiko Porsche 911, 74 Lachs-Diamant Metallic |
For the original poster thinking of adding a passenger side mirror. What color is your car? I ask because if it's something very common (like Guards Red) and non-metallic, you could probably buy a passenger side door with mirror and mount it up. For ease of installation, I'd keep it manual. Of course, if it were me, I wouldn't install a passenger side mirror. But if visibility became big enough of a concern that I absolutely had to install a passenger side mirror, I'd use chrome durant mirrors because they are manual, I like the way they look, and installing them is a reversible mod. |
Thanks guys. The guy I'm buying the car from says he has the template and can put the holes in for me - I just have to find a mirror now. Thanks larry I'll pm you now, anyone else with any suggestions of where I can get one would be great - I actually live in Ireland btw
I just purchased a 76 Targa with no passenger side mirror. I'd like to leave it the way it is but I'm concerned about changing lanes safely. Hopefully I'll be in the left lane most of the time but unfortunately you do have to jump into the right lane occasionally. Any input from owners without right side mirror would be appreciated. Why did some cars come through without the mirror, was it an option?
Sugar Scoops Rule :)
I've had my 76 targa without a passenger side mirror for over 27 years, and haven't had any issues changing lanes yet
. Visibility out of these cars is great.I'm glad I left mine as is -- when I bought my car I thought about blacking out the chrome trim and roll bar and adding a passenger side mirror, but I'm really glad that I've kept everything original like it came from the factory.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
I've driven plenty of cars for many years without the passenger side mirror. It's takes a bit more awareness, but it's not a big deal...you get used to it.
I have a 77 911S Targa, no passenger side view mirror. Can see just fine without it. Kinda cool, offbeat, who wan't everything symetrical anyway?
Dam it I've already had the holes drilled! Ah well, it may save me one day!
still looking for a left hand side mirror if anyone knows where i can get one! |
Side mirrors.......
Is your car a left or right drive car? I have two (2) sets of flag mirrors in my garage collecting dust. PM me your email address and will send you some pictures and pick your choice (blue or brown).
Tony |
