Sugar Scoops Rule :)
dave 911's Avatar
Help needed - rear caliper piston alignment (w photos)
I've got myself confused on the orientation of the 20 degrees. The photos are of my left rear caliper. #1 is before the pistons were removed:
This one is how it seems like it should go, and how I put the first piston in, referring to the diagram in the tech instruction, before looking at my 'before' photo above - with the side closest to the inside of the wheel lower than the outside:
This is putting the other piston in that same caliper, the same orientation as it was in the 'before' photo:
This seems wrong, when I compare to the diagram, and when I hold it up to the car, but I doubt that they were installed wrong...I've never had any squealing, and I don't think they've ever been off the car (car is a 76, I've owned it since 84)
Can anyone help clear up my confusion and confirm which one is correct?
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 02-11-2012, 07:21 AM
aj88cab's Avatar
The notch is oriented into the rotation of the rotor. In other words as the rotor turns it first passes the notch.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 02-11-2012, 08:05 AM
pete3799's Avatar
Pete
79 911SC RoW
Old 02-11-2012, 08:44 AM
dave 911's Avatar
yes, that's the diagram I'm using, and that's why I'm confusing myself. This picture is of a caliper on the right side of the car, correct?
So I'm assuming that the 'fat' part of the template should be on the inside of rotor, or the same side of the caliper as the mounting bolt holes - yes?
The first photo I posted is of a left side rear caliper w/ what I assume is the factory installation, and it seems backwards from the diagram. Is the before/dirty photo correct, or is 2nd photo I posted correct? Again, all photos are of the left rear caliper.
Thanks for the help!
Dave
'76 911S Targa
Old 02-11-2012, 09:07 AM
Diss Member
Quicksilver's Avatar
Don't worry about right or left. Worry about the gauge going on the side towards the rotation and the wider end goes in.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-11-2012, 09:16 AM
another way to look at it..and keep oriented
think of the pad as a water ski, you want more weight on the back, therefore the raised part of the piston is put on the trailing side of the pad
Sold: 1989 3.2 coupe, 112k miles
Old 02-11-2012, 10:14 AM
dave 911's Avatar
Thanks for the help guys. The piston was installed incorrectly for all these years - go figure....
Dave
'76 911S Targa
Old 02-12-2012, 06:20 AM
I've had them spin on me, I think more than once
Old 02-12-2012, 05:31 PM
dave 911's Avatar
And here I was thinking that the boys at ATE had a few too many Lowenbraus at the Biergarden before their shift back in '76 .
Dave
'76 911S Targa
Old 02-12-2012, 06:27 PM
