Noise when depressing clutch
Hi:
Here is the problem. Engine recently rebuilt by me. Sounds great. Took it for a short ride and notice that when I depress the clutch pedal there is a ticking sound that is annoying. It goes away when the clutch is released. The clutch engages and works OK, new pilot bearing. And by the way the engine was smoking from the fan belt area (crankshaft area). No oil leak, I will check the belt tension tomorrow.
Any thoughts will be appreciated,
Francisco Soto
Old 02-11-2012, 02:39 PM
what year and what trans. off the top of my head when you depress the clutch pedal you are either pulling or pushing your throw out bearing, did you replace the throw out bearing?
Old 02-12-2012, 08:39 AM
sub
+1 need info. on year/etc.
Sold: 1989 3.2 coupe, 112k miles
Old 02-12-2012, 08:44 AM
Forced Induction Junkie
WERK I's Avatar
Does it make the noise when the car is stationary, moving or both?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 02-12-2012, 09:53 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Car appears to be an 85 3.2 with a turbo added.
993 ss cams in 3.2 turbo
Old 02-12-2012, 10:34 AM
lonewolf's Avatar
clutch not adjusted properly
Old 02-12-2012, 01:11 PM
Hi everyone:
Car is a 1985 carrera with 915 tranny. Today I started the car and went for a very short ride. No noise (ticking) in the tranny. About the smoke in engine compartment found the crank pulley with a wobble (only the A/C part). Probably the smoke was from the belt. Need to check that. The fan part of the pulley is running true. Have to go for a longer ride (actually no permit to drive until april) to check for the smoke and the ticking. Probably is when the car is getting to temperature.
Thanks for your replys and keep them coming,
Francisco Soto.
Old 02-12-2012, 01:12 PM
