9dreizig's Avatar
Send a message via AIM to 9dreizig
Pressure plate is stuck!!!
86 turbo.. original clutch.. dropped the engine to freshen the tranny and clutch.
transmission came off no problem ,, removed all 9 bolts , starter ring came off no problem
now the pressure plate seems stuck.. any ideas ??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-12-2012, 03:50 PM
mine took some time to come off,...
i sprayed the outer edge with some Liquid Wrench, let sit, put all bolts back in, hit it a couple times with rubber mallet, took bolts back out, hit with rubber mallet, and it popped loose
1980 930, just did this a couple months back.
Old 02-12-2012, 04:11 PM
9dreizig's Avatar
Jim,
What is the purpose of putting the bolts back in and out ?
"Todd"
Old 02-12-2012, 04:12 PM
clean up any rust that mught be arount the edge of the flywheel so it can slide out. you may be able to knock at it with a punch through the bolt holes from the backside. should be just a matter of working it loose
Old 02-12-2012, 04:23 PM
9dreizig's Avatar
p dude,, can't get to the flywheel until the pressure plate comes off...
"Todd"
Old 02-12-2012, 04:27 PM
Originally Posted by 9dreizig View Post
Jim,
incase one side started to come out and other didnt, it wasnt coming straight off, try to straighten it out...
Old 02-12-2012, 04:31 PM
lonewolf's Avatar
Did you get water in there before you started?
sounds like the disc is stuck to both sufaces. If you removed the bolts there is nothing holding it on.
If it's the stock rubber center disc some may have come off and is help sticking the parts together.
just tap it off
Old 02-12-2012, 05:00 PM
9dreizig's Avatar
wolf,
I don't believe I've ever gotten water in there.. I don't think there's a rubber center either,, looks just like my 80 which didn't have one I think they dis-continued them after 86 or so.. ..
I've tried tapping and hitting with a plastic hammer. I've also tried driving it sideways so the plate slips over the outside of the flywheel , but it's not budging .. the holes to the flywheel still line up
"Todd"
Old 02-12-2012, 05:25 PM
lonewolf's Avatar
Well.
If it's unbolted then there is nothing holding it on.
Must be fused together.I've seen it happen
Old 02-12-2012, 06:12 PM
9dreizig's Avatar
So Wolf if you've seen it ,, how did you free it ??
"Todd"
Old 02-12-2012, 06:20 PM
do you have a torch? you need to heat up around the edge, try to expand it.
Old 02-12-2012, 06:21 PM
lonewolf's Avatar
We drove a wedge between disc and flywheel
your p plate has not released.
when you unbolted it ,it didn't release
heating it up could work.
We are not there but you are so look at it closely and see what going on.
when you unbolted it the p plate should have expanded but sounds like it didn't
and it's stuck on or rusted on. when was it last drivin?
Old 02-12-2012, 06:30 PM
Just tap it off with a plastic mallet.
Old 02-12-2012, 07:04 PM
lonewolf's Avatar
Yes .it just may be a question that your not hitting it hard enough or with the wrong tool
Old 02-12-2012, 07:19 PM
pry it off with a big screwdriver. normal.
206 637 4071
Old 02-12-2012, 08:44 PM
9dreizig's Avatar
guys, I've hit it, pried it, swore at it!!!
Put liquid wrench on it tonight, hopefully it will loosen up tomorrow
"Todd"
Old 02-12-2012, 09:01 PM
bigger screwdriver and pry harder.
206 637 4071
Old 02-12-2012, 09:16 PM
lonewolf's Avatar
come off?
Old 02-14-2012, 07:21 AM
9dreizig's Avatar
Finally yes!! thanks for the advice!!
Just needed some persuasion!!
"Todd"
Old 02-14-2012, 07:26 AM
