915 jumps out of 1st
My 83 SC is jumping out of first. I have read some posts, and I have checked the linkage, etc- all ok. What actually would cause it to jump out of gear?
Mine does the same. Same car, btw.
The Uncertainty Principle. It proves we can't ever really know...what's going on. So it shouldn't bother you. Not being able to figure anything out. Although you will be responsible for this on the mid-term. -Larry Gopnik |
I'm a loser, baby.
Possibly bad trans/engine mounts. Start with the small stuff first. Mounts seemed to help mine.
1979 911 SC |
Immature Member
Assuming you are properly in 1st gear (no issues with coupler misadjustment) there are two things that 'lock' the tranny in gear: one is the shift sleeve (slider) snapping over the synchro ring, the other is a spring loaded detent on the shifter shafts that helps lock in the selected gear and locks out other gears.
As far as I know, the detents aren't a common wear item, so it is most likely worn synchronizer ring/sleeve teeth. If your transmission also crunches when you try to engage 1st while still rolling it is most certain your 1st gear synchronizing components are warning you.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
check your drainplug magnet for little broken teeth.
What does a brand new tooth look like? Opened up mine today and on a few of the rings, the teeth are full size only half way up one tooth then the rest of the tooth is about 2mm thinner
'80SC ROW '76S Wide Body '87 G50 Coupe '69T Bahama Yellow |
OK, I found several teeth on the drain plug this morning, so I spent the rest of the day pulling the engine/trans. My plan is to open it up, replace the broken parts and put it back in. I was having trouble getting in 2nd before it started jumping out of 1st. I know exactly when I broke 1st- I was really beating on it at the time because of some jackass in traffic. I should have known better.
Immature Member
![]() John - have you given any thought to diagnosing Porsche problems as a career?
Senior Advisor
Skool of hard knocks my friend, John has sean 100's of these things. Oh and yes, he is the Dean!!
Hey IMSA GTU #55, what is the engine hoist connected to?
08 Cayenne Turbo Last edited by James Brown; 06-27-2010 at 05:30 PM.. |
James- It's a pain jacking the car so high to get the engine out(jack stands don't go that high), so I remove my fiberglass bumper, lower the engine/trans, then lift the rear of the car with the hoist, and roll the engine out. I hook the chain hooks to the factory tie downs on both sides. I had this out in a couple hours by my self, no sweat.
Senior Advisor
cool, nice job. are you rebuilding the trans. yourself?
08 Cayenne Turbo |
Yeah, I'm going to give it a try. It looks pretty straight forward. I'm pretty handy when it comes to cars
Air Cooled Addict
Hey IMSA,
Where in Tampa are you? I'm in Brandon, so if I can be of assistance, let me know. Did my first tranny last year and, with the help of JW and this board, she's been great since. Even put a 2 day DE at Sebring on her with not a whimper. I've got the shaft nut tool if you need to borrow it. Anything to help out a fellow Tampon.
Joe V '84 Schwartz 911 Carrera 3.2 '91 Specialized S-Works M2 - Gone but not forgotten '12 Trek X-Cal : American Classic - XT brakes/shifters/derailleurs - carbon goodies '13 Trek Madone 5.2 stockish |
Hey Joe!
My car hobby shop is near the RJ stadium. Thanks for the assistance offer, I might need it. Sounds like yours turned out good. Karl |
Pete Zimmerman is putting together some kind of tutorial on rebuilding a 915. Not sure if he's mentioned it here or on Rennlist.
Also, Siene has instructions on blueprinting 915 shift linkage: Seine Systems > Blue Printing the 915 Shift Housing |
you can rebuild the 1st/2nd syncro assembly without even removing the trans from the engine. both out of the car of course. end cover off, 5th and reverse items off, leave the fork clamped to the shaft and slide it off with the shift sleeve, remove guide fork plate off the center housing and then remove center housing, exposing the gears and shafts. carefully remove the roller bearings, mark where the 1st/2nd fork sits so you can duplicate that (leave it's shaft alone), and the rest is obvious. there's a detent in the end of the center housing that needs to be all the way down against the spring before installing the housing.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-28-2010 at 05:45 PM.. |
John,
Good idea. I got the engine/trans on the bench and tore it most of the way down after work. I took the center housing off, and sure enough 1st/2nd is completely shot.
Detached Member
That is how I pulled the engine in mine with an engine hoist. I owned the hoist, so why buy RV jackstands and an RV jack?
Hugh |
Senior Advisor
Does sound like a slick idea, I have the 1/2 ton stands, they don't go that high. And I have a engine hoist from the "old days". Might put it to work!
08 Cayenne Turbo |
IMSA, I'm impressed at how quickly you go after it!! Good job.
