fuel gauge won't work - any ideas?
Gents-Need a little assistance-
I have a Fuel Safe Porsche 911/930 cell (SA101) in my 1976 911 with a fuel gauge from a 1991 911. Have tried getting to work a few times with no luck. Fuel Safe has not been very helpful. Any suggestions I would really appreciate any feedback. Thanks Roger |
Maybe these threads will help:
Broken wire inside fuel tank sending unit fuel guage needle is stuck??? Pelican Mini-Technical Article: Repairing the Fuel Tank Sending Unit
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
Thanks for the reply. The gauge has never worked since the car was restored. The fuel cell was brand new and I had the gauges checked out by North Hollywood Speedometer. I'm not sure if these would apply to my situation but thank you very much.
Member 911 Anonymous
Bench test the gauge with a power source, it it does not peg then re-flow the solder joints and check again.
Take a DVM and see if the connector are getting voltage when ignition is in the on position. Take care to not allow the hot lead to ground on to the chassis.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Will Do. Thanks!
