Air Cooled
Craig_D's Avatar
WEVO Engine Mount Install Pics
I bought a full set of WEVO Black engine and tranny mounts from our host and installed the engine mounts this afternoon. Thought you might like a look-see.
It was pretty straight forward...I followed the 101 Projects directions of one complete swap per side.
The WEVOs are gorgeous! Serious bling and good upgrade. Haven't taken her for a drive yet...will report later. I'll post when I do the tranny mounts next
Enjoy!
- Craig_D
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 02-20-2012, 06:06 PM
Air Cooled
Craig_D's Avatar
Next set:
'69 Honda CL350
Old 02-20-2012, 06:09 PM
Vintage Motorsport
RichardNew's Avatar
I did two Wevos and 2 Club Sport. Not quite as rigid but maybe better for the street. It made a difference in how my 915 trans shifted.
Richard Newton
Facebook
Old 02-20-2012, 06:25 PM
I love my WEVO mounts. In my experience, I don't think they add much more to NVH in the cockpit compared to worn out stock mounts. They definitely helped my 915 shift a little smoother. The only thing bad about WEVO parts is that you have to mount them in areas that people can't admire their beauty.
Old 02-21-2012, 04:41 AM
SuperOldSchool's Avatar
To install, is it just a matter of supporting the engine with a jack and unbolting/dropping in new mounts?
Is the handle poking out of the engine compartment just another floor jack supporting the forward portion on the engine?
SoS
1987 Triple Black Cabriolet - Wide Body
2011 Black Cadillac SRX
2007 Black Honda Element SC 5spd (for sale!)
2015 Yukon XL Denali
1966 VW Karmann Ghia
Old 02-21-2012, 05:39 AM
Dublinoh's Avatar
Same question, "To install, is it just a matter of supporting the engine with a jack and unbolting/dropping in new mounts?"
Also what was the symptom/problem that convinced you to replace the engine mounts?
Old 02-21-2012, 06:00 AM
Northern Motorhead
wildcat077's Avatar
I installed the Blue Pillow Wevo's last Summer in order to tighten up all the old rubber ends on my car and i didn't notice any more noise or vibrations ...
Turns out my 23 year old bushings were completely squashed so this was a good move !
Like the boys say,just support the engine and out with the old,in with the new
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-21-2012, 06:13 AM
I think the handle is a makeshift hood prop. Make sure to fully support the weight of the drivetrain before taking out the old mounts.
Old 02-21-2012, 08:04 AM
toddu's Avatar
hmmm, mine didn't have the black gasket looking thing. Neither did the old ones that came out.
Todd
'81 SC
Old 02-21-2012, 08:11 AM
I think that "black gasket" is a shadow. No gaskets in mine. The only issue in this project is the potential difficulty of removing the large center bolt in the OEM mounts. Use anti-seize in the new installation.
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 02-21-2012, 10:33 AM
gavinc69's Avatar
Well pleased with mine
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP
Old 02-21-2012, 11:02 AM
toddu's Avatar
Ha, do I feel stupid!! Was originally viewing the page on my phone. Clear as day now viewing it full size.
Todd
'81 SC
Old 02-21-2012, 02:57 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
What's the difference between the blue and black versions?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 02-21-2012, 03:14 PM
toddu's Avatar
Blue are less compliant, "stiffer".
Todd
'81 SC
Old 02-21-2012, 03:20 PM
The OP's first pix showed 4 pieces, but the "install" pix only showed 2.
Are there 2 or 4 per vehicle?
Also, what were the symptoms that motivated the install?
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 02-21-2012, 03:31 PM
Almost Banned Once
sc_rufctr's Avatar
These are a great option to OEM mounts. You need four of them for the SC/Carrera cars. Two at the engine, the ones you can see the photos and two at the gearbox end.
I've been running blue pads for about 8 years. Great but I want to try the more complaint black pads next time I have my engine/gearbox out.
Worn engine/trans mounts can adversely affect shifting.
- Peter
Old 02-21-2012, 03:43 PM
TDIDog's Avatar
Has anyone done the transaxle mounts on a 930?
Old 02-21-2012, 03:45 PM
theclaw's Avatar
Any issues with getting the front pair mounted?
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 02-21-2012, 05:25 PM
John W
They look nice. I'm thinking of replacing mine. What's the best way / place to support the engine and then the trans. to do the swap.
This forum rocks.
Thanks in advance,
John
89 3.2 Targa 123k miles
Old 02-21-2012, 05:59 PM
Formerly known as Syzygy
Canada Kev's Avatar
Support the engine with a jack and do just one side at a time. The mount you didn't remove will locate and support the engine while you have the other out.
Kevin
Old 02-21-2012, 06:37 PM
