Wer bremst verliert
How much weight can be stripped out of a door?
The car is pure track, with a stout cage built in. I have a little time on my hands and am considering stripping the doors back...how much weight can be pulled out?
Club requirements are for windows that can open and close, so was planning on leaving the glass and motor there, unless there is a plastic alternative that is reasonable to fab and cost. I guess I'm a bit skeptical just how much weight can come out...the door cards dont weigh much, nor the trim. Speakers are long gone, the pockets and handles are already gone and replaced with a strap. I dont want to replace the door due to $, was wondering how much people have pulled out...this is a 1983sc. thanks
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Chain fence eating turbo
Why not remove the regulator and motor?
Just use a strap to hold the window up. Maybe that is not allowed?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
porsher
I just finished a door gutting project: scroll down a bit
Gutted Door Pix? I saved between 27 and 30 lbs/door, sorry my weights are not more accurate.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car Last edited by aston@ultrasw.c; 02-13-2012 at 10:32 AM.. |
porsher
And here's some info on non-glass windows.
By reviewing various threads and doing some research I conclude the following: Polycarbonate: (lexan etc) Good impact resistance, poor abrasion resistance and expensive. Acrylic: (Plexiglass etc) Poor impact, good abrasion but cheap. So there are now abrasion resistant grades of polycarbonate: Lexan MR10 for example, which is even more expensive. 48" x 48" x 3/16 $300 Or, impact resistant acrylic: Plaskolite Optix for example, a little more expensive but still a bargain in comparison. 48" x 48" x 3/16 $50
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Wer bremst verliert
Hmmmm...54-60 lbs would be a nice save...when you say "a strap to hold the window up" can you show a pic of what you mean?
Or...the ultimate weight reduction...a carbon fibre door with lightweight Lexan fixed window.
Bob
Bob Hutson |
I just did what bob said. I love the doors. I went with GT Racing EVO II with a lexan slide window (I know that is against your rules). The doors with window and hinge weigh in at around 9lbs a piece. Original doors are in the 50lbs range.
I feel like 27-30lbs is a bit of a stretch, but I could be wrong. Take a piece of thin plywood and wrap it in alcantara with a strap for pulling the door closed as mentioned above. Goodluck. Chris |
Stahlwerks.com
Cut out the safety beams if you want to take significant weight.
i have a EURO drivers side door for sale, passenger just sold, significantly lighter then US spec door, and can remove safety beam
I have been looking at this too. I was contemplating gutting the doors to get the weight out, but if you can save a bit and are not too strapped for cash remove the doors in good working order and sell them. There is a Porsche dismantler near me and I am just going to be selling them everything I stripped out of my car. I won't get top dollar, but it saves a lot of hassle and opens the budget up for other things.
Once the doors are gutted you can't really go back. |
For door lock mechanism I fitted one of an older Peugeot 105 (green), cheap and very light because all plastic. Removed beam and cut out inner wall. Instead of I glued in a 3mm FG plate. As I am in the middle of a project, can't tell you weight, it's all disassembled, but I can tell you that the raw door as in the second pic is not heavier than a FG door ![]()
Roland 930 Turbo '81 Too many modifications to list |
Wer bremst verliert
Thanks guys, very helpful.
Does the plexi/lexan/makrolon scratch on the felt or rubber seal on the bottom of the window from raising/lowering?
Wer bremst verliert
And can the safety beams be removed without damaging the outer skin? In situ?
Yes, not much room for working, but I did it. The only thing you have to do is cut the inner wall out first
I can't remember exactly, but think it was around 4-5kg each. I can weight the door stripped as on pic on my post, so you can see how much you can save
Wer bremst verliert
The answer was 45 lbs.
Mine is a RoW car and didnt have any beams in there. Cut them right back and painted in rubberized rocker paint. ![]() ![]() ![]() ![]() ![]()
![]() ![]() Roll bar extension across the door is work in progress Chris |
porsher
I used an impact resistant acrylic, Plaskolite Optix and it slides smoothly without scratching. I am using both felt (new) and rubber (old) seals.
AutoBahned
what does that 45 lb. number refer to?
