Speedometer Question
Hello All, SmileWavy
I have an 84 Carrera with a stock 3.2. :cool: This may sound like a dumb question but can I drive the car without the speedo in place? :rolleyes: I'm going to have the speedo worked on but still need to drive the car; is this going to disrupt anything, electrically? I don't want to short something out. Let me know your thoughts. Thanks. ;) |
Your car won't care. Just make sure to take a picture of the back of the speedometer with all of the wires attached before you disconnect anything. Easier to remember months later when you go to reinstall.
speed-ometer.
http://forums.pelicanparts.com/uploa...1329928288.jpg |
Thanks for the "heads-up" and photo.
its appreciated. |
Make sure nothing "hot" can ground...I have read several times about owners melting wires, smoke etc
Wrap each connector with good electrical tape and then tie them up in a location where they cannot touch each other or ground. Label them well and take good pictures. Make yourself a drawing too.
Good form to disconnect battery before removing speedo also
If you have it, the cruise control wont work as I am almost positive that it takes an output from the speedo. Other than that you should be fine.
Regards Dave |
| All times are GMT -8. The time now is 04:46 AM. |
