The Dilivar Studs Are Out
All twelve Dilivar studs are removed! Used an oxygen/acetlyene torch to gently heat the case and they came right out. Now I'm ready to install the steel studs and reassemble the engine. Is the thread on the stud a standard 10M15. I wanted to run a tap in the case to clean out the hole.
John |
10x1.5 it is.
Senior Member
That's a nice sight, jadams!
Be sure to protect those rods from flapping around, hitting the case and such.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Author of "101 Projects"
Unless you're going to toss it into the back of a pickup truck and drive off-road, there's not too much damage that your rods can do just sitting there...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Senior Member
Navin Johnson
the case is aluminum, or magnesium..
the rods are steel.. Im not seeing how the rods can be damaged anyway any stress risers can be dressed with some crocus cloth
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Schleprock
Be sure to use a thread chaser to clean the threads, not a cutting tap.
Kevin L '86 Carrera "Larry" |
Thanks !
John |
KTL, I'm not having much luck finding a 10x1.5mm thread chaser. Is it the same as a flat bottom tap or medium tap? I own a 10x1.5 mm starter tap. What do I need to buy? I've looked in Grangers, McMaster-Carr and MSC.
John |
Schleprock
John,
They're like these: Thread Chaser Set Never used them myself, but these guys are what you're supposed to use to clean your threads.
Any other options besides the thread chaser? I'm trying to keep the tool investment cost down and I was hoping to install the studs on Saturday.
John |
Senior Member
ASt this point in my rebuild, maybe 8 weeks ago, I checked into this "thread chaser versus thread cutter" controversy. All of the professional mechanics I spoke with said "What?" Oh, you know, thread chaser, but not a recgular cutting tap. They said "What?" again. Then they said "I use a tap. What's a thread chaser?"
So, I used a tap.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
