Front Strut Tab Washer Question
I was replacing the washer on my front struts with my recent strut replacement. Does the tab washer that sit between the cup/saucer washer and nut on top get bent upwards to hold the nut in place? I know that the car has some nuts held in place by a bent washer. Or does it stay flat and provide tension to lock the nut?
Thanks, Chuck |
It should be a warped washer, not bent up
The tabbed washer is not warped, if you are meaning wave washer.
Thanks, Chuck |
my recollection is that on my SC the washer was designed to be bent up to lock the nut, as you surmised. you use a punch to flatten it to remove the nut. on some cars it may have been replaced with another type of lock washer.
| All times are GMT -8. The time now is 12:15 AM. |
