Send a message via AIM to mercury26 Send a message via MSN to mercury26 Send a message via Yahoo to mercury26
Front Strut Tab Washer Question
I was replacing the washer on my front struts with my recent strut replacement. Does the tab washer that sit between the cup/saucer washer and nut on top get bent upwards to hold the nut in place? I know that the car has some nuts held in place by a bent washer. Or does it stay flat and provide tension to lock the nut?
Thanks,
Chuck
Old 02-24-2012, 10:45 AM
It should be a warped washer, not bent up
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-24-2012, 02:07 PM
The tabbed washer is not warped, if you are meaning wave washer.
Thanks,
Chuck
Old 02-24-2012, 02:10 PM
schumicat's Avatar
my recollection is that on my SC the washer was designed to be bent up to lock the nut, as you surmised. you use a punch to flatten it to remove the nut. on some cars it may have been replaced with another type of lock washer.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 02-25-2012, 05:13 PM
