RE: 1975 911 2.7 CIS (US, CA. CAR) with dealer installed AC.
Preping my car for Saturday morning valve adjustment. My first time! Trying to locate TDC and n't find Z1 on the pulley. I found a stange looking 1(number) with a single notch. When lined up whith the notch on the engine housing the ditributor is lined up with the notch on the distributor housing. I tried this in two consecutive 360 degree rotations and it lined up. Could thid be my Z1?? ERIC
1975 911 Carrera BLK/BLK |
Not sure about the 75 but on an 82 there are 2 notches
one at Z1 and very close at 5 degrees. almost right next to each other. If you are truely on Z1 the No. 1 intake and exhaust valve should be able to rock the rocker arms......
