Banned
Carrera 3.0 Cam Timing
I am finishing up a engine rebuild on my 77 3.0 Carrera
and am installing ands setting the camshaft timing next Wanyes Book states for the 76 3.0 CIS valve overlap is .9- 1.1 on the dial gauge Is this the the same setting for the 1977 3.0 C stock and is this the best setting for a 667XXXX engine thanks!!! |
Thats the spec on the 8.5/1 pistons. I did the cams today on an 81 and the 9.3 calls for 1.4 to 1.7 and its all the same cam. Remember the C3.0 was euro only.
Bruce |
Banned
hi thanks.
yes the 1977 3.0 Carrera has 8.5/1 pistons so the correct is 1.0mm overlap |
