-   -   Caliper Rebuilding Question! (http://forums.pelicanparts.com/porsche-911-technical-forum/660961-caliper-rebuilding-question.html)
Geneman 02-26-2012 03:13 AM
Rebuiliding Boxster Calipers (for 911 upgrade) after powder coat etc. All new hard lines and brass fittings ordered from Pelican.
(see pic along with other parts of beauty from Pelican/ERP for a complete front end rebuild winter project!)
Do you use loctite on all these fittings when re-assembling? does it matter if red/blue stuff?
how about on the brass washer for the banjo lines ?
thanks very much
Frankhttp://forums.pelicanparts.com/uploa...1330258408.jpg
air_cooled 02-26-2012 08:08 AM
I'm almost certain nothing in this job requires Lock-Tite. (Red requires heat to remove, or blue requires a wrench) Those brass washers are the gaskets and require nothing but proper torquing of the fittings.
gregwils 02-27-2012 09:23 AM
No loctite is the correct answer. If you are anal about sealing, you could put a very small dab of Curil-T on the threads, but you don't need it and you don't want to get it in the fluid.
