Just some guy
My search-fu is weak.. heat/defrost cable 80sc?
Hi guys - I've spent half an hour searching thru PP for the cable that controls hot air distribution at the dash. Since I need $12 more for free shipping on my brake rebuild project, I figured this overdue item would fit the bill, but I can't find it anywhere!
I think it has a red housing, but not sure... goes from the bottom (red knobbed) lever in the dash panel, controls the outlet of the hot air (def/heat).
Any help?
Old 02-26-2012, 05:16 PM
ROW '78 911 Targa
timmy2's Avatar
Hmmm, my parts manual shows those cables as part of the entire control assembly that is NLA.
Porsche 911 & Carrera Dashboard & Steering Column - Page 5
You can buy generic cables like that from restoration houses ( I bought them for a '56 pickup truck) or take it over to a bicycle shop and have them make one? Post a wanted to buy ad?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-26-2012, 06:54 PM
Just some guy
Thanks for the info, have to see if I can fab something up....
Old 02-27-2012, 08:27 AM
skunked's Avatar
Kyle,
I went through this recently and came to the conclusion that those cables are NLA as mentioned above. I found a used control panel with the cables FS here on the classifieds fro $50. Make sure you grease the cables well, that's usually what causes them to break in the first place.
FWIW, I've been told that cables from a lawn mower can be rigged to work.
-Mat
78 911SC
Old 02-27-2012, 10:15 AM
Chief Head Scratcher
kerthunk's Avatar
You can get some hi-tech replacements from a bike shop. I believe that you will want control cable vs brake cable.
John Morris
'79 911SC
Old 02-27-2012, 02:53 PM
Just some guy
Thanks guys - control cable for push-pull capability; makes sense, though I would have bought brake cable the first time.
Fresh air blower doesn't work, hot air blower doesn't work, heat/def control doesn't work. Bout on par, I'd say.
Old 02-27-2012, 02:55 PM
skunked's Avatar
Might be a good time to backdate the heat.
-Mat
78 911SC
Old 02-27-2012, 03:46 PM
ROW '78 911 Targa
timmy2's Avatar
It's always a good time to backdate the heat!
The OP needs to be able to send it where he needs it!....
Dennis
Old 02-27-2012, 04:28 PM
Just some guy
Yup, a BD is on my list, along with reverse-park wipers, AC fix-or-remove, oil line replacement, valve adjustment, speaker replacement, suspension refresh, lower/corner-balance, R-comps, track days, AX....
For now, baby steps - let's make it safe to drive again.
Old 02-27-2012, 04:56 PM
Flat Six
Flat Six's Avatar
Might be wrong, but IIRC even derailleur control cables are "pull only" as they operate in tension against spring-loaded components.
Solid lawn mower cables, though, might work . . .
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 02-27-2012, 05:05 PM
