door hinge repair question
This is the ?hinge? on my door; on both doors the screw is 'popping' when the door opens, due to the screw that you see in detail. I wanted to get everyone's input on the best way to repair this mess, so that I no longer hear the popping sound and to ensure the door is operating as it should.
This is a 1984 911 cab with a 993 rebody kit, if that helps. ![]() ![]()
1984 911 Cabriolet 1999 Land Rover Discovery II |
The "popping" sound is probably the metal inside the door flexing. It's a common problem with these cars.
There is a repair kit available but might require taking the door off. That depends on the condition of the existing metal. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_BDYchs_pg2.htm#item11
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
ROW '78 911 Targa
Lots of info using the search function:
Driver door "CLICKS" when open/closes Go with post #7 from John Walker.
Fleabit peanut monkey
See john walkers post in this thread. I have seen him mention it several times. '73 door popping noise from hinge |
1st, that should be a pin not a screw. Remove it and see if both ends are secured properly. Normally the piece inside the door starts to come loose and it is a pain to fix. Hopefully with a new body side piece and proper pin and grease the problem will go away, it looks as if it has never had grease.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
