-   -   First breakdown. Gutted. Please Help! (http://forums.pelicanparts.com/porsche-911-technical-forum/661633-first-breakdown-gutted-please-help.html)
M0nster 02-28-2012 12:53 PM
I only had my lovely Carrera 3.0 a week and its broken down. It's been running great, took it for a very long drive at the weekend and it was fine. Started perfect Monday, today started quickly but seems to struggle a tiny bit - before kicking in. Same on the way home from work. After a 10 minute journey i stopped in to get some fuel. When I went to start the car again it was dead. Tried a few times, it would try one or two rotations but give up. Very strange for this to happen all of a sudden - I know I did not leave the lights on or anything.
So, I jump started it and it did start ok but the lights seemed very dim when I turned them on. My mate had a little battery tester gadget and it said it was not charging. Battery is new. Hmm. Drove 1 minute down the road and was waiting at the lights around the corner from my house, sitting in neutral and she just cut out! Awful. had to push her around the corner through the traffic. My underground car park in my apartment block has a steep decline so tried to jump start it but made a balls of it. Sitting at the end, I tried to jump start it again but it was not starting at all - not lights coming no or anything. The battery tester gadget was not registering anything at all! All that was happening was a clicking from under the bonnet at the front left, which I think is the alarm (Toad). It started to click at different rates then later, very strange. Not sure what to do about this. The drivers window was down and still is, I could not get it back up. It should be safe behind the gates of my carpark but its hardly ideal.
I took out the battery and its charging, I'm going to try to put it back in either later tonight or tomorrow morning and maybe it will start. Would 4 hours on a halfords all in one automatic charger give it enough to start it? Maybe I'll wait until the morning to give it a full charge.
I'm going to call my breakdown service in the morning and get it towed to my mechanic. I'm not sure how these cars can be towed, it will need to be pulled out from the back, can that be done?
Any advice you guys can give me would be appreciated.
tsiegwart 02-28-2012 01:09 PM
Sounds like your alrternator is not working. If you charge the battery, it may start and drive again for a little while until the battery goes dead again. You could drive it home on the battery.
It's not difficult to replace the alternator. Mine's on it's 3rd in 150K miles.
Flat6pac 02-28-2012 01:13 PM
or your voltage regulator could be toast.
Bruce
Driver_X 02-28-2012 01:24 PM
In your car, the Alt & the VR are one unit. Not a hard job at all.
Search on Pelican for Alternator & Voltage regulator. Loads of info, most importantly you want to check your voltages at different RPM's. Many threads on this. I have one of the volt-meter's you put in the lighter socket so I can monitor my Alt. They are cheap & easy to use. I would suspect that once your battery is charged (time needed depends on your charger) your car should start right up. Close your window and see if you can report back with your voltages at the various RPM's (you'll find what you want to look for in the other threads).
Where are you located, you might be able to get a local Pelican to lend a hand....
shipfaced 02-28-2012 02:08 PM
Don't tow it!! Get a rollback flatbed to haul it. By the way, I have an alternator out of an '80 for sale. The plastic(!) bearing shim gave up on the first day of a 3 day DE. Overnighted a new alternator in and replaced at track then made new brass shim for old (60k mile) alternator.
Dublinoh 02-28-2012 05:20 PM
Check that you still have a belt on your alternator, loose battery cable could do this too
DRACO A5OG 02-28-2012 08:49 PM
+1 on alternator.
When my alt went out, I suspected the battery, charged her and was fine for couple of hours then died, found the alt was shot and not charging the battery ergo no spark to the plugs
If you have AAA service they will come out and check the entire system for you so you can zero in on the culprit.
Bear911 02-28-2012 09:15 PM
Just curious, does the red alternator warning light (below the the oil warning light on the oil temp/press gauge... I assume it is red like mine) come on when you turn the key in the ignition and then extinguish when the engine starts?
tazzieman 02-28-2012 09:49 PM
The long answer is "yes".
A voltmeter is a cheap and easy addition to the monitoring of the car's vitals.
Voltmeter vs. Ammeter - Auto Meter Tech Tips:
Danny_Ocean 02-28-2012 10:24 PM
He's in Ireland(?). http://www.earthsongforums.com/forum...lt1/smiley.gif
Bear911 02-28-2012 10:51 PM
<div class="pre-quote">
Quote de <strong>Bear911</strong>
</div>
<div class="post-quote">
<div style="font-style:italic">Just curious, does the red alternator warning light (below the the oil warning light on the oil temp/press gauge... I assume it is red like mine) come on when you turn the key in the ignition and then extinguish when the engine starts?</div>
</div>The long answer is "yes". <br>
A voltmeter is a cheap and easy addition to the monitoring of the car's vitals.<br>
<a href="http://www.egauges.com/ATM_Tips.asp?TipPage=voltmeterammeter.htm" target="_blank">Voltmeter vs. Ammeter - Auto Meter Tech Tips:</a>
Sorry, what I meant was, does M0nster's Alternator light extinguish as per normal? Normally an alternator failure should stare you in the face, not so? Unless the bulb is blown or there is another issue.
M0nster 02-29-2012 01:37 AM
Thanks for all the advice guys - really appreciated. I charged the battery for a few hours last night and put it back in - thankfully I was able to get the window up so its secure, but I could not get it started. Definitely the alarm - its made by Toad. The green LED on the dash was flashing - usually its just one been turns it on or off, light is red or green - simple. I have an alarm guy coming to help me today.
My question, if the alternator is dead, if I have a fully charged battery, how long will I be able to drive for realistically? I do not want to die on the way to the garage. it's only about 3-4 miles. But I died yesterday after getting jump started and only driving a few hundred yards.
How much is a new alternator?
ant7 02-29-2012 02:18 AM
Hi,
If your going to try and drive it in the daylight, then a fully charged battery should last at least a few miles as long as you dont use anything else ie; lights, heaters etc, to be honest though, i wouldnt move it and would get the mechanic to come and look at it where it is, it could be the alternator, or wiring behind it, but it could also be a large drain on the system caused by a short etc, that is more worrying and the reason i wouldnt try using it untill you know whats wrong, also, if it is the alternator, and it siezes up, then you dont have any engine cooling either as the fan is driven off the back of the alternator via the belt.
Hope this helps.
Anthony.
unclebilly 02-29-2012 03:05 AM
The voltage regulator in my 77 is external. It is under $30 and should be available at any autoparts store. It is a 3 prong connector next to the fuse panel in the engine bay. It is a sub one minute repair. The replacement may not look the same as the original.
My gues it is this o a battery terminal that is corroded or not connected properly.
ivangene 02-29-2012 04:26 AM
Colin, do you have a Bentley yet?
you can get an free online version - not as good, but OK, search Porsche Manuals and look for a site from cannell.co.uk
download as PDF and save it - might take a few tries its big
after a full charge on that battery get it checked for condition (load test)
once its good start the car and use a volt meter to check voltage output (needs to be at about 2500 rpm) - buy tools not a tow, you will be $ ahead in the end.....
Ed
ivangene 02-29-2012 04:29 AM
as for driving with a non-charging system - DONT!
I take it your alarm didnt come with a remote? Most alarms have to be turned off after a battery install. My old one had a hidden reset button that required "key on" and push/hold reset button...simple if you knew were the reset button was...contact old owner, might know
Justin@Athens 02-29-2012 05:34 AM
Check for a bad ground from the battery to the tub right there in the front boot. Also check for a bad ground at the transmission ground strap directly under the middle of the car. Please check both of these grounds before you spend a bunch of money replacing stuff!
M0nster 02-29-2012 05:37 AM
Thanks guys. So I'm just back - got her started :) I charged the battery last night - and got an alarm guy to come look at it today. I put the battery back in, clicking the button on the remote would make noise but the LED was not lighting up which was strange. Started it, and she started fine! So annoying. It did not do this last night Anyway he showed me how to bypass it if it happens again. I'm going to get a new alarm in it.
So, tomorrow I need to drive it up to my mechanic. Is it ok to drive it 2/3 miles if the battery has had a full charge? If i use the choke to keep the revs above 2000 will it be ok or is it likely to die?
Justin@Athens 02-29-2012 05:42 AM
You can try it I guess. Although, as ivangene posted above you could damage your DME and the rest of your charging system if the battery dies or is "removed from the loop." There are other threads about this same scenario. I am going out on a limb here--but I'd say your alarm has nothing to do with your no start problem.
Rot 911 02-29-2012 06:02 AM
Speaking from experience you can get about 30-40 minutes driving out of the battery.
M0nster 02-29-2012 06:07 AM
Justin thanks yes I will certainly check this - cheers. Any other bits I should be checking also before replacing stuff? Can you easily test if an alternator is broken and needs replacing? Hopefully my mechanic will check these things - but let me know anything you think he should check and I'll give him a list :)
Can anyone point me to the right part for the alternator on pelican? Thanks :)
M0nster 02-29-2012 06:09 AM
Thanks Rot911 that's a load off my mind!
Justin@Athens 02-29-2012 06:15 AM
One thing you can do and want to check is the charging voltage while in the car. Use a $10 voltmeter from Autozone to check that your battery is reading 12v while the car is off. Anything less then 12v will not start the car, and is considered bad. Now start the car and do the same test--you should be getting at between 13-15v with the car running at 3k rpm. If you do not appear to be getting a good charge, it could be an intermittent problem, or it could be that something has failed entirely. The alternator can be removed from your car and bench tested at Autozone. You can also have them rebuilt at certain truck shops and such. Pelican will want your unit in exchange for a rebuilt unit--just give them a call and tell them your model year and they will make sure you get the correct part.
ivangene 02-29-2012 06:17 AM
guessing there are no Autozone's in Ireland :p
Justin@Athens 02-29-2012 06:19 AM
i'm sure there is some equivalent:rolleyes:
ivangene 02-29-2012 06:27 AM
was just joking....
so Colin.....you are running in two directions...one is getting the car to the mechanic, the other is find/buy parts on Pelican...slow it up, I know its frustrating and you need your car but choose a path....
work on it yourself requires time, tools manuals and beer...
take to mechanic requires time, money and beer...
If your guy is a couple miles away, run it over and have him look at it. He will do exactly the same things we are telling you here...test battery, test charging system with some sort of meter. If he diagnosis it for you, you can always opt to change parts yourself... so the trip is still worth while. Dont buy parts till you know what is wrong, an alternator is a spendy part to buy and might be you just need a VR....
As stated you can sorce those pretty cheap but I would advise to buy a good one if you end up in that boat. Cheap ones tend to leave you stranded at some point
M0nster 02-29-2012 07:24 AM
Thanks Ed you are absolutely right. I'm really not great with mechanics so I'd prefer to get an expert to do it rather than potentially mess it up myself. It's going in tomorrow so I'll let you guys know how I get on.
Thanks again for all your help!
jpnovak 02-29-2012 08:25 AM
FYI, this is a C3.0 No DME to worry about. Forget anything anyone posted regarding damage of the DME.
Do you have a multi-meter for measuring voltage?
You can easily measure the battery voltage with the car off and then again with the car on to see if the alternator is charging.
javadog 02-29-2012 08:34 AM
You don't have a choke, by the way. That's a hand throttle, which allows you to idel the engine at a higher speed while warming it up, without having to keep your foot on the throttle pedal. I wouldn't drive the car with the lever up. Just use your foot...
JR
M0nster 02-29-2012 03:03 PM
Thanks Javadog, ahh ok - mine often idles quite high for the first few mins etc, can bounce around a little but I'm sure thats normal. Anyway at least if I'm at traffic lights etc I can set the idle higher so she won't cut out on me.
So today I charged the battery again which only took a short while to get full. I got one of these alternator and voltage testers and tested it. When the battery was out it read fully charged 12.6v. When I put the battery in, it read 12.0v - half charged. When the engine was running it should show 13.2v "Charging ok" but it read the same Half Charged with the Fully charged light flickering. So it's fairly clear my alternator is busted.
I'm told they are pretty dam expensive - up to €250, but maybe thats just in ireland. How do I know what part etc to search for - I have no idea where to start looking!
at7driver 02-29-2012 03:18 PM
Hey, you have confirmed the belt is still on??? If the belt is slipping or off, no charge and more importamtly no air cooling for your engine.
M0nster 03-06-2012 04:32 AM
My mechanic just text me to say it was the voltage regulator. Phew! Small part and cheap to replace. Good news! Getting a few other little things fixed also, can't wait to have her back for the weekend!
Next up is Ed's coupler which arrived in the post this morning! Can't wait to get that fitted and see the difference it makes!
diverdan 03-06-2012 06:49 AM
Sounds like a charging problem, but don't overlook the health of the battery.
Bear911 03-06-2012 07:09 AM
That's good news. Sounds like Bruce was on the money as usual!
lonewolf 03-06-2012 07:40 AM
I have the correct voltage regulator if you need one
Bruce
s_morrison57 03-06-2012 10:05 AM
MOnster, Glad you have things working again, its a real bummer to get your dream car and then have trouble right away, same thing happened to me with my 930, my failed part shut off the fuel pumps on over rev, I wasn't over reving it, I have a little bit of mechanical skills but had no clue where to look. it was a few months later that I found this place.
Hats off to all the Pelicans that lent some advise to a new owner/member, its you guys that make this such a great place.
Hard to believe that M0nster is the only Irish member.
Good luck with the new car and send us a pic or 2 and the story on how you found your car.
Finn
M0nster 03-06-2012 10:15 AM
Yes thanks so much to all the pelican's for all their helpful advice for newbies like me! Hopefully I'll have her back this weekend and I'll let you know how I get on!
M0nster 03-07-2012 10:47 AM
Oh also guys, would anyone have any advice on how I can fix this problem?
http://forums.pelicanparts.com/porsche-911-technical-forum/661964-speedo-odometer-stopped-working-my-77-911-a.html
Thanks!!
Porchcar guy 03-07-2012 12:31 PM
North Hollywood Speedometer will test and refurbish !
M0nster 03-07-2012 12:42 PM
Thanks! Unfortunately I'm in Ireland lol - so a little far away ;). I'm just wondering how you might test for what has gone wrong and try to fix it?
