Strange electrical problem
I have been trying to adjust my mixture, this has happened twice now, I hook up my dwell meter to the test plug by the rear harness, while I make my adjustments, the battery is getting drained, and I mean quickly, the car stays running but in just a few minutes the tach begins to go hay wire and then dies completely, once I shut it off I have to hook up a battery charger, anyone have this problem? I verified my connections, positive on dwell meter to the green wire and negative to the brown wire, I need to use the meter method because I can't get my hands on an o2 meter, any ideas will be appreciated.
Senior Member
What kind of car, year etc? Need more info to troubleshoot. Something is not correct as you should not be able to run the battery down that fast.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I knew I was forgeting something duh!
Sorry, the car is a 911 80SC
